Soldering...
Okay, this is here because I need it for my ICE gear.
I need to learn how to solder.
I need to know...
1. What's the best type of iron to get, and where?
2. What accessories do I need?
3. How to learn to do it?
I know a tiny bit about it, but have never done it, at least not properly. I currently have and am taking back that "Cold Heat" piece of crap.
Please be descriptive and include links/pics.
Butane? Electric? Gas stove?
:roll: :arrow: wink.gif
I need to know...
From: Lillington, NC & Maryville, TN when I can get there
Ok here's a quick little how to:
(also here's a larger PDF file on how to solder)
How To Solder
Soldering is defined as "the joining of metals by a fusion of alloys which have relatively low melting points". In other words, you use a metal that has a low melting point to adhere the surfaces to be soldered together. Soldering is more like gluing with molten metal than anything else. Soldering is also a must have skill for all sorts of electrical and electronics work. It is also a skill that must be taught correctly and developed with practice.
This document attempts to teach soldering through a few simple steps. Tips and tricks are also provided at the end.
How To Solder
Step 1: Equipment
Soldering requires two main things: a soldering iron and solder. Soldering irons are the heat source used to melt solder. Irons of the 15W to 30W range are good for most electronics/printed circuit board work. Anything higher in wattage and you risk damaging either the component or the board. Note that you should not use so-called soldering guns. These are very high wattage and generate most of their heat by passing an electrical current through a wire. Because of this, the wire carries a stray voltage that could damage circuits and components. The choice of solder is also important. One of the things to remember is to never use acid core solder. Acid core solder will corrode component leads, board traces and form conductive paths between components. The best solder for electronics work is a thin rosin core solder. I prefer a thickness of 0.75mm, but other thicknesses will also work. Just remember not to get anything too thick.
Remember that when soldering, the rosin in the solder releases fumes. These fumes are harmful to your eyes and lungs. Therefore, always work in a well ventilated area. Hot solder is also dangerous. Be sure not to let is splash around because it will burn you almost instantly. Eye protection is also advised.
Step 2: Surface Preparation:
A clean surface is very important if you want a strong, low resistance joint. All surfaces to be soldered should be cleaned with steel wool and some sort of solvent. Laquer thinner works well. Some people like to use sand paper, but I think that it is all too easy to sand right through circuit board traces, so steel wool is my preference. Don't neglect to clean component leads, as they may have a built up of glue from packaging and rust from improper storage.
Step 3: Component Placement
After the component and board have been cleaned, you are ready to place the component on the board. Bend the leads as necessary and insert the component through the proper holes on the board. To hold the part in place while you are soldering, you may want to bend the leads on the bottom of the board at a 45 degree angle. Once you are sure that the component is properly placed, you can more on to the next step.
Step 4: Apply Heat
Apply a very small amount of solder to the tip of the iron. This helps conduct the heat to the component and board, but it is not the solder that will make up the joint. Now you are ready to actually heat the component and board. Lay the iron tip so that it rests against both the component lead and the board. Normally, it takes one or two seconds to heat the component up enough to solder, but larger components and larger soldering pads on the board can increase the time.
Step 5: Apply Solder And Remove Heat
Once the component lead and solder pad has heated up, you are ready to apply solder. Touch the tip of the strand of solder to the component lead and solder pad, but not the tip of the iron. If everything is hot enough, the solder should flow freely around the lead and pad. Once the surface of the pad is completely coated, you can stop adding solder and remove the soldering iron (in that order). Don't move the joint for a few seconds to allow the solder to cool. If you do move the joint, you will get what's called a "cold joint". This will be discussed shortly.
Step 6: Cleanup
After you have made all the solder joints, you may wish to clean with steel wool or solvent to remove all the left over rosin. You may also wish to coat the bottom of the board with laquer. This will prevent oxidation and keep it nice and shiny.
Cold Solder Joints
A cold joint is a joint in which the solder does not make good contact with the component lead or printed circuit board pad. Cold joints occur when the component lead or solder pad moves before the solder is completely cooled. Cold joints make a really bad electrical connection and can prevent your circuit from working.
Cold joints can be recognized by a characteristic grainy, dull gray colour, and can be easily fixed. This is done by first removing the old solder with a desoldering tool or simply by heating it up and flicking it off with the iron. Once the old solder is off, you can resolder the joint, making sure to keep it still as it cools.
Tips and Tricks
Soldering is something that needs to be practiced. These tips should help you become successful so you can stop practicing and get down to some serious building.
Use heatsinks. Heatsinks are a must for the leads of sensitive components such as ICs and transistors. If you don't have a clip on heatsink, then a pair of pliers is a good substitute.
Keep the iron tip clean. A clean iron tip means better heat conduction and a better joint. Use a wet sponge to clean the tip between joints.
Double check joints. It is a good idea to check all solder joints with an ohm meter after they are cooled. If the joint measures any more than a few tenths of an ohm, then it may be a good idea to resolder it.
Use the proper iron. Remember that bigger joints will take longer to heat up with an 30W iron than with a 150W iron. While 30W is good for printed circuit boards and the like, higher wattages are great when soldering to a heavy metal chassis.
Solder small parts first. Solder resistors, jumper leads, diodes and any other small parts before you solder larger parts like capacitors and transistors. This makes assembly much easier.
How To Solder
How To Solder
Step 1: Equipment
Step 4: Apply Heat
Step 6: Cleanup
Cold Solder Joints
Tips and Tricks
damn. lots of reading. have fun with that redz. heres what im gonna say:
1. soldering iron. as a starter, you dont need one that you can control temp with. i really reccomend that butane soldering iron i showed you before. check in my needle DIY, there is a link. I used that for EVERYTHING!!!!, and i still have half a bottle of butane left from the three that i started off with a year ago. im talking everything too. there are attachments for a hot air blower(for heat shrink), torch(for making fire...lol or for high temp heat shrink), a hot knife that will cut through virtually any plastic you need it to, and of course, the soldering tip.
2. the main thing to try and remember, is that the solder joints you make are much better if you try to melt the solder on the things you want to connect, not melt it on the tip and then smear it on the joint. to do this, i usually put the solderin iron right underneath the joint, sometimes holding it up. i melt a little solder on the tip of the iron REALLY close to the joint. this allows some to get to the joint, and heat it up fast. after that is done, start pressing the solder on the joint, and if it is hot enough, it will begin to melt on the joint and FLOW thorugh it(loooks pretty cool), ensuring a good connection.
3. as far as solder, get 60/40 and thats all you will need. the numbers represent the lead/tin ratio in the solder. higher lead concentrations are used for stuff like electrical connections, while higher tin is used for stuff like plumbing( and requires a LOT more heat). get this and you will be good:
http://www.allelectronics.com/cgi-bin/cate...-032&type=store
so all you need is:
that soldering kit
some butane(the tubes with the nozzle on the end....from like a grocery store or something)
that solder in the link
and might as well get some speaker wire cheap from walmart or something to practice with.
DAMN, my words per post count has got to be going up.
so all you need is:
that soldering kit
what the link to that gas one? I've got my old electic one but the cord is often annoying. oh, btw, I don't know about the gas one, but a nice stand /w a sponge is a must!!!
Vehicle: 2004 Acura TL
REDZMAN glad you asked cause I didn't have the balls to ask especially after the circuit board thread earlier.
Awesome writeups guys, Blu's was a little long winded but informative none the less. As for tibby01 I would expect nothing less. Thanks guys.
I would definately do as tibby01 recommended and get the butane irons. The only thing you need an electrical one for is electronics repair. You are just going to be joining wires and stuff and not having to deal with a cord rocks!
another nice thing about the butane... you are not tied to a work bench or even an extension cord (been there, done that) if you have to a quick repair somewhere.
