Rca Cables?
Old Jun 20, 2005 | 05:15 PM
BlackTibby00's Avatar
I bought a set of RCA cables to run my front stage components. Now there is the left and right channels, then there is a third, smaller wire that runs down the middle with a spade connector on each end. Now what is this wire for? Do I just ground it out on the body at each end? I'm guessing if that is the case of grounding it, that it's for less distortion or interference.
Old Jun 20, 2005 | 05:21 PM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
I suck at electronics but I would say that yes that would be the ground. I'm not sure if you should need a ground with RCA's though.
Is it possible that those are just the connectors for the other side of the RCA's? I dunno, I thought they just went from port to port.
Old Jun 20, 2005 | 05:55 PM
never even heard of this, but tapping into ground at each end wouldnt hurt anything.
Old Jun 20, 2005 | 05:59 PM
hyundaijvx's Avatar
Vehicle: Honda
You got a picture of them?
Old Jun 20, 2005 | 06:02 PM
it almost sounds like a video cable... generally they have three RCA ends per.. one for each channel of sound and a Yellow coated third RCA for the video signal.
Old Jun 20, 2005 | 06:11 PM
spiceflow's Avatar
It's a remote turn-on wire for your amp.
Old Jun 20, 2005 | 06:13 PM
Old Jun 20, 2005 | 06:17 PM
fonseca's Avatar
Yep, remote turn on. You must have bought a fancy pair.
Really only useful when wiring just a sub amp imo.
Old Jun 20, 2005 | 07:57 PM
It could just be a remote turn on, but why use spade terminals to hook it up? I could see it being at the amp end, but not the deck end. I'll post up a pic later so you can see what I'm talking about.
Old Jun 20, 2005 | 08:27 PM
javageek's Avatar
You can buy wire taps that take the spade end. That's probably what is intended.
