Paint Doesnt Stick?
Old Aug 13, 2004 | 08:01 PM
douknowme12321's Avatar
Default Re: North East Chapter Members
For some reason the paint is not sticking to the primer on the dash. No matter how many coats the primer just seems to seep thru. Did anyone ever have this problem?
Old Aug 13, 2004 | 08:15 PM
MADTIB's Avatar
Default Paint Doesnt Stick?
What do you mean that it seeps thru? Does the paint kinda like crack up and have weird lines thru it like veins?
Old Aug 13, 2004 | 08:29 PM
Default Re: Clutch question
no, no matter how many coats you put, once it dries you still see the primer gray.
Old Aug 13, 2004 | 10:40 PM
Hobgoblin's Avatar
Vehicle: 2015 Subaru WRX
Default Re: Hot Import {Daze} Nights Oct. 23
This may sound bad... and I dont mean for it to... but Ive seen it before... You DID let the primer dry, didnt you?
Old Aug 13, 2004 | 11:17 PM
MADTIB's Avatar
Default Re: high pitched sound (radio)
Well, the last thing I was saying would have to do with if you were applying an enamel to a laquer.You can not paint an enamel on top of a laquer.You can go the other way around,however.
Are you sure the primer and paint are dry? Drag your finger nail thru it.Does it peel right up like it's kinda wet? If so,the problem is humidity.
Primer especially doesn't like to completely dry during humid conditions.
Old Aug 14, 2004 | 06:10 AM
Default Re: Chrome Outside Door Handles
Oh thats definitely it! You wouldnt believe howww humid it was up here yesterday, my guess is that i used a wrong type of primer, imma try again soon, but imma have trouble taking this crap off... :roll:
Old Aug 14, 2004 | 08:55 AM
MADTIB's Avatar
Default Re: Electrifying Tib!!
So you were able to drag your nail thru it and have the paint come up?
Yeah,if you think removing paint is a b****,you should try removing heat activated adheasive some time. 8O
EDIT******
Next time,test the paint on something you don't care about.Make sure everything is working correctly.Also, you may want to skip the primer.I've done several paint projects without primer,and things actually worked better without.
Old Aug 14, 2004 | 08:59 AM
Default Re: Guess I gutta start over...
Locking, go to other thread.
Don't make duplicate threads on the same stuff.
