Many Many Mods(56k Killer)
Gdamn man, thats just crazy. when i think your done and putting everything back together to enjoy your tibl; you make another post with 6 billion things your wiring in. I hope that you put this much passion into your performance mods too. Finish this crap up so we can see! cool.gif
GAH! CarPC pictures. almost forgot....
not much of a carpc right now as it is a home mini pc, but here they are:
workstation:
random antennas(xm,gps,wifi, and a tv antenna somewhere around here):
stuff turned on:
pretty illuminated keyboard:
yeah, that will fit nicely once the plastic frame gets chucked. what is it going into though...ahhhhh. look closely wink1.gif
and alex, upper level performance stuff is coming. im already making a shopping list. still have the wilwood stuff to put in too. smile.gif
workstation:
stuff turned on:
first, pull back the rubber loom. unclip harness from insde the cabin. use small screwdrivers/similiar substitute to undo 4 clips holding door side connector of harness to door jam. then you just want to make notches in the connector on the door side so that you can feed wires through the thing when it is closed up. then of course, use a coat hangar to feed the wires through the rubber loom stuff and into the door.
dayum man... im afraid to take any interior stuff out for fear of it not going back together right.... you gutted your car... shoulda just called the factory and ordered a new steel body and everything and just wired in what you wanted smile.gif
