Ground effects problem
Old Dec 2, 2004 | 12:38 AM
2bits's Avatar
Default Re: Interior Neon Tubes
This was my first install with lighting......
Everything is great, it looks amazing, i hooked it up to a switch, i made a custom piece to mount into where my ash tray use to be, and put the switch into there, i really like it. I used like 24 gauge wires though, form the battary to the switch then back into the system. i think this is where the problem is.
Only my back light doesnt light up, Thinking it was the bulb i replaced it, but the same thing happens, it lights up some times, only part way, if i run my hand along it, it would light up fully. This only happend when the car is off, but now it happens when the car is on. Is this becuase of the tiny wires used at the switch, i already replace the bulb, so it cant be that....
Old Dec 2, 2004 | 07:16 AM
JalemX's Avatar
Default Re: Vader kit
i had the same problem turns out it was a short in the wire in the tail light bullb assy. maybe you're having the same prob cause i have underlights too and tho unrelated idk... but try playing with the wire when someone is stepping on the brakes.
Old Dec 2, 2004 | 09:12 AM
MADTIB's Avatar
Default HOLD light?
Sounds like a bad connection to me.It's not a 'short', and it's not due to 24ga wire.Look over your crimps/connections.May also be a bad connection in the neon
Old Dec 2, 2004 | 09:51 AM
BillyDee01Tib's Avatar
Default Re: CEL -p0441/emmissions leak... T/B cleaner?
Yeah if youre pressin on the light or messing with it then it sounds like it might be in the actual light itself.
Old Dec 2, 2004 | 11:07 AM
2bits's Avatar
Default Re: 04 CVVT Turboed - Speed Factor kit
I thought it was the light too, so i replaced it, and still doing the same thing. I guess it has to be a short somewhere then, in the spring i am ripping all the wireing out and redoing it...
Old Dec 2, 2004 | 12:16 PM
FlyRyde's Avatar
Default Re: FS-JVC KD-G700 and 1frd RF capacitor
almost every time I've heard of this, its a fuse.
Old Dec 2, 2004 | 01:14 PM
MADTIB's Avatar
Default Re: I need some help on making a decision
QUOTE (2bits)
There are other things that can be causing a 'loose' or 'bad connection', which is what you have.IT"S NOT A SHORT!! If it were a short you'd keep blowing the fuse.And if you don't have a fuse, you'd burn the thing up and possibly burn up some things in your car.
