Door Speaker Install Help
I have the speaker out of the door... but i noticed there is no place to run the new wire from the new speaker to the amp... as in there is no hole to get the wire through the door. I know there must be somewhere... can someone tell me how to get that wire from the speaker in the door back to my amp?
Also, could i just tap into the stock speaker wire that goes to the head unit with a wire then take that wire to my amp?
i understand that i can be done, but iv spent over an hour trying to fit the wires into it and it wont go anywhere
also.. where is the tweeter wire connected too? as in, where to the wires lead to?
lol try putting loom lube or grease on the wire and shove it through. there is no technique to it, just shove it through.
as far as tweeter wires go, dont worry about the stock wire you are going to run new wire to your x-over.
