Does RCA thickness alter sound performance?
Old May 3, 2011 | 01:58 PM
hawk's Avatar
Vehicle: 2004 Tiburon GT
Default Does RCA thickness alter sound performance?
Hey guys, I was wondering something. Ive seen some really expensive rca audio cables (from the head unit to the amp) that were really expensive and Ive seen the cheap radio shack rca's that were only a couple of dollars. When it comes to speaker wires, power wires, and ground wires, I know its good to have a thicker gauge depending on how much power you're pushing. Is it the same with rca's or do those cheap ones from radio shack do the job just as well?
Old May 3, 2011 | 02:37 PM
pas1216's Avatar
Vehicle: 1991 Impulse RS
like most things in life, you get what you pay for. I wouldn't buy the most expensive ones, but definitely not the cheap-o ones either! Find a good quality set reasonable priced and you should be good to go.
Old May 3, 2011 | 02:44 PM
Go to http://www.monoprice.com and get yourself a set of RCA's there. Super high quality, and very cheap in price.
Old May 3, 2011 | 05:09 PM
holeshot69's Avatar
Vehicle: 1998 Tiburon
Make sure you get car audio specific! Also run it down the passenger side of the car as well.
Old May 3, 2011 | 10:31 PM
If you make your RCAs out of unshielded untwisted speaker wire, you will get noise. A basic set of shielded RCAs will get you all the signal quality you need. Step up the ladder one level in price and you will get cables that do not degrade/corrode internally over time. Step up again and you get cables that will last forever if you treat them reasonably. Step up again and you are buying only a name brand. Consider road noise and then think about the non-difference you won't hear by overspending on cables.
