How EXACTILY does the steering wheel come off?
how Exactily does the rd 2 steering wheel come off? i got the 2 screws for the airbag, the 1 big main nut and now i need to know how to unplug the air bag from the colum... does it jus pull off, twist off? i tried once with no luck and its kinda sketchy for me to handle an air bag at my chest/stomoch lol i unhooked the battery let it discharge and took out the airbag fuse jus to make sure it wouldnt go off in my lap. so please help me out i would like to get it on today (5-4-11)
Vehicle: 13 Gen Coupe Ult.
After you get the air bag loose from the wheel, then you just simply undo the conector, there are two one for the airbag signal wire and one for the horn, horn just comes off from the right side of the air bag, and the other one is just a small clip, helps to get to it if you take the column surround off. (just those two plastic parts that surround the column) now take the big nut off the wheel, and give her hell, if you dont have a bearing puller it just takes a bit of beating and wiggling, but she will come, but Be carefull install you new hub and take it for a test drive and make sure your wheel is aligned right cause if not it will be alot easier to remove the wheel and move it a splin BEFORE you torque it down!
also there is a little way you can get your turn signal cancler to work, just have to drill three small precise holes in the aftermarket hub adapter to match the three fingers on the cloumn!
