Components or 4 way speakers
Old Jul 22, 2011 | 12:33 PM
BobG's Avatar
Vehicle: 2007 Accent
Default Components or 4 way speakers
Which is better for front door speakers...components with individual tweeters and speakers or a good set of 3 or 4 way all in one speakers?
Old Jul 22, 2011 | 01:24 PM
It depends...if you're running the speakers off of an amp, I would go with components as they usually can take alot more power than regular all-in-one speakers. Otherwise if you're just going to run them off the stock wiring and head unit...go with a good quality 3 or 4 way speaker.
Old Aug 26, 2011 | 09:40 AM
Tomte's Avatar
Vehicle: 2001 Hyundai Tiburon 2.0 G4GF-EG
Even 2-way coax speakers do suffice for the headunit and offer enough sound quality. 3way or 4way is not necessarily better.
Components do sound better, but may also be more expensive and harder to mount (tweeter).
Another reason than power to go for components: If you have mounting spots (like the tiburon RD) for tweeters you would raise the stage ie the music is directed at your head rather than your feet. That does sound a lot better. Most seperate tweeters come with housings that can be mounted on the dash. A-pillar mounting may put the speakers too close to your ears.
Old Aug 26, 2011 | 10:41 PM
There is no reason to get a 4 way speaker for a car, period. 3 is pushing it, and 2 is all you need for a well-designed speaker from a quality manufacturer.
Old Aug 27, 2011 | 08:13 AM
seperate amp = component
no amps = 2-way speaker
Old Aug 28, 2011 | 12:53 PM
Tomte's Avatar
@BobG you can take my "not necessarily better" and turn it to "not worth it" as in: I wouldn't do it.
