Angel Vents?!
Old Feb 8, 2003 | 05:40 AM
phorq's Avatar
Default Angel Vents?!
Well, after experimenting with the DIY for angel eyes... i got to thinking, and came up with this. unfortunately, it was too cold and the day ended too soon to get to the dash vents, and the other door. but now that i sorta know what i'm doing, the next warm-ish day here in new york will be the day to finish this up. I also think that i want to fix the bright spot where the LEDs are, and move it to the top left, where it isn't quite as visible.
[ February 08, 2003, 12:41 PM: Message edited by: phorq ]
Old Feb 8, 2003 | 05:58 AM
Shadohh's Avatar
Dude, that would own. If hook it up to your HEAT/COLD
Old Feb 8, 2003 | 06:01 AM
phorq's Avatar
that could be very possible with a little knowhow with the heater dial wiring... there are 2 LEDs in each ring, you COULD put one red and one blue that would alternate on/off to light the ring.
Old Feb 8, 2003 | 07:01 AM
JESUS.
Dude, that OWNZ!
I need a DIY on that fo sho.
Keep us up to date.
Old Feb 8, 2003 | 07:56 AM
phorq's Avatar
well, i did end up putting the passenger side halo in, i just need to figgur out how to run the wires into the car without it looking too ghetto. (pics were taken with a 9V battery). i'll make a DIY for ya Redz when i finish the center vents.
Old Feb 8, 2003 | 08:18 AM
Thanks mang.
You know if I could rate you 5 again, I would.
Love the dash too. Think that's the first time I've seen yours.
EDIT: BTW, are you using the Acrylic rod like the guy in the DIY? Hard/easy to use? Also, how hard is it to get those cuts spaced?
[ February 08, 2003, 03:21 PM: Message edited by: REDZMAN ]
Old Feb 8, 2003 | 08:20 AM
Viper966's Avatar
i did those in my car a while ago... but i only did the middle vents, i took it out cuz the led overloaded cuz im an idiot
Old Feb 8, 2003 | 08:29 AM
phorq's Avatar
yeah, i'm using the blinds/acrylic rod. before i heat it in my toaster oven at 350 degrees, i put it next to a ruler and mark off the ticks (3mm apart) with a thin sharpie, and cut when the circle is perfect. it took me about 3 or 4 re-heats to get it just right. and even though the rod is very pliable when heated, i just use my hands to hold it, it's not so hot you need to use pliers. oh, and use the lip of the top of a soda can for just about the right size in these locations.
Viper, what did you do to overload the LED? i've been known to be an idiot at times, so if you could gimme a heads up, i'd appreciate it.
[ February 08, 2003, 03:31 PM: Message edited by: phorq ]
Old Feb 8, 2003 | 12:29 PM
Viper966's Avatar
just used 2 small of a reisistor and popped one... trust me if u try 2 pop one u can...
