12v Source From Door?
Old Jan 2, 2006 | 12:34 PM
cdubb's Avatar
Where can i get a 12v source from my door panel??
Im putting neons in the little pockets on the door, and i cant find a 12V source?
Old Jan 2, 2006 | 12:54 PM
brian01tib's Avatar
IDK where one is in the door but you can prolly have a wire from the fuse box (strip a wire find an empty fuse spot wrap the wire around a fuse prong and put the fuse in) right there and run it with the little wires to the door.
Old Jan 2, 2006 | 01:15 PM
01SilverShark's Avatar
maybe this will help
http://www.rdtiburon.com/index.php?showtopic=74
Old Jan 2, 2006 | 01:31 PM
when do you want them on? all the time, at night, with a switch?
Old Jan 2, 2006 | 10:23 PM
cdubb's Avatar
either whenever i turn my lights on, or just whenever the car starts up...
i tried hooking it up to the green wire...but it dont think i was getting any power from it??
i wasnt sure which wire was which tho on my neon....is the clear w/ stripe usually the ground or power???
i tried it both ways...but no luck either way
any suggestions???
Old Jan 3, 2006 | 10:28 AM
I ran a power wire to the doors for my lights. Looks great.
Old Jan 3, 2006 | 10:39 AM
there is a green/white wire running to the power window switch. you want to tap into that one.
Old Jan 3, 2006 | 09:38 PM
cdubb's Avatar
thanks tibby
which wire is usually the power wire for neons???
i have a clear w/ blue stripe...and just a clear wire
i forget which one was which when i removed them from under my seats
Old Jan 3, 2006 | 11:29 PM
He just told you what wire. The green with a white stripe.
It's in everyone's door, you may have to peel some covers out of the way to find it.
Tibby01, how about a CONSTANT power in the door? LOL
Old Jan 4, 2006 | 11:44 AM
he means the wires connected to the neons, and i dont know. i would go with the one that has the stripe being power though.
