RPM gauge
Old Sep 26, 2004 | 10:46 AM
  #21
Default Re: RPM gauge
You don't have to have the battery disconnected, just have the keys out of the ignition and the door closed.
Old Sep 26, 2004 | 08:34 PM
  #22
Default Body Kit
you cant get the dash off with the soor closed. well, not easily at least.
im going to guess red was power, black was ground, green was an ignition turn on type wire, and yellow was the tach signal wire.
Old Sep 27, 2004 | 11:43 AM
  #23
kidwell03's Avatar
Default Re: my clubgtr front totaled? how to reglass?
Red=power, black=ground, green= tagsig, yellow, I just pluged into the little tiney conector coming out of my indeglow gauges.
Old Sep 27, 2004 | 02:11 PM
  #24
Blu_Drgn's Avatar
From: Lillington, NC & Maryville, TN when I can get there
Default Re: SUPENSION BARS??
when i took my dash apart i never got a airbag light what causes that (i didnt disco the battery, real smart seeing as im an electrician i should know better)
Old Sep 27, 2004 | 03:03 PM
  #25
tibwrcsbj's Avatar
Default COLORS
I didnt get the airbag light either.....BUT.........
I do have a Half brightness CEL. Invisible during the day, visible at night, actually its prob a little less than half power/brightness.
Old Sep 27, 2004 | 03:52 PM
  #26
silvertibbs's Avatar
Vehicle: 2004 Acura TL
Default Re: Zefiro Gen I frp vent hood
I wondered why my airbag light came on. Can we fix it somehow??
Old Sep 27, 2004 | 05:14 PM
  #27
Default Re: My SS turbo exhaust manifold custom made by AXIS
yeah, 40 bucks at the dealer.
you may have just gotten lucky that it didnt come on.
Old Sep 27, 2004 | 05:18 PM
  #28
Blu_Drgn's Avatar
ive had it off like 3 times and never disco'd the batt and never gotten a light neither...wierd?
Old Sep 27, 2004 | 10:59 PM
  #29
Default Re: ~Tasty~ --- The Speed-Factor turbo kit has arrived, pics
Like I said.
You either need to have the battery disconnected or have your keys completely out of the ignition when you take the cluster out.
Old Aug 4, 2005 | 04:46 PM
  #30
Mr_Hyde_NT's Avatar
<div class='quotetop'>QUOTE (REDZMAN @ Sep 25 2004, 06:14 PM)</div><div class='quotemain'>Take it apart.
Once you have, with the keys out of the ignition, take out the Gauge Cluster.
On the back is a screw that says "Tac Sig" or somthing. Run a wire to that for your signal. Then just wire up some power.
please, don't hate me, i didn't want to open a new thread for the same reason, but i need to refresh this because i'm goign to install my rpm gauge too..
according to what i found on hmaservice, on this pictures there is the main two connectors on the back:
following, in the next pictures there is the pin out of both:
so that, the question is: the pin number 5 of the IO1-2 connector is the wire i need for my rpm gauge (rpm signal) ... or should i really found that screw ? is it so clear to find out that screw before i begin to remove everything ?
