1/4 mile
Old Jan 14, 2005 | 01:00 PM
injected's Avatar
Default 1/4 mile
what does a stock 2.0 tib run on the 1/4 ???
what will get me into the 14's
besides big money items like within 1000 $$$ ??
Old Jan 14, 2005 | 01:11 PM
LarryMcFly's Avatar
Nothing under 1000$ will get you there.
Old Jan 14, 2005 | 01:18 PM
Dweet's Avatar
you can do it under $1000 with nitrous
Old Jan 14, 2005 | 01:19 PM
Clean2k1Shark's Avatar
itll be close to 1000 tho
Old Jan 14, 2005 | 01:26 PM
JonGTR's Avatar
No it won't. $400 NX kit + $30 Eclipse pump = easy 14's.
edit: actually, I was running 14's with the stock pump.
Old Jan 14, 2005 | 02:00 PM
Dweet's Avatar
I dont think you really need the eclipse pump... but thats just my opinion
Old Jan 14, 2005 | 02:13 PM
CyberShark's Avatar
<div class='quotetop'>QUOTE (injected)</div><div class='quotemain'>what does a stock 2.0 tib run on the 1/4 ???
besides big money items like within 1000 $$$ ??</div>
A stock Tib is supposed to do around a 16.2 to 16.3 if you have a 5speed. An auto will be slower. You will not be able to to 14's n/a with that amount of money unfortunately.
Old Jan 14, 2005 | 02:18 PM
hamhead's Avatar
Most NX kits I see are mid 550ish dollars... I personally would never buy a used nitrous kit for the same reason I never buy a used turbo... I don't know what its been through. And I would at least recommend he get the Gen-X upgrade kit... bottle warmer, gauge, etc. Keeping the PSI constant in there is necessary to keep the system safe. Your probably looking at 800 dollars to run a 75 shot safely.
Old Jan 14, 2005 | 02:24 PM
Dweet's Avatar
<div class='quotetop'>QUOTE (hamhead)</div><div class='quotemain'>Most NX kits I see are mid 550ish dollars... I personally would never buy a used nitrous kit for the same reason I never buy a used turbo... I don't know what its been through. And I would at least recommend he get the Gen-X upgrade kit... bottle warmer, gauge, etc. Keeping the PSI constant in there is necessary to keep the system safe. Your probably looking at 800 dollars to run a 75 shot safely.</div>
good point.
Old Jan 14, 2005 | 02:30 PM
Jaws021's Avatar
<div class='quotetop'>QUOTE (CyberShark)</div><div class='quotemain'>A stock Tib is supposed to do around a 16.2 to 16.3 if you have a 5speed. An auto will be slower. You will not be able to to 14's n/a with that amount of money unfortunately.</div>
yea.. start removing seats and all that crap..
Its possible...
Brendan did it with an elantra...
