Hyundai Hybrids Want to drop in a Beta for your Hyundai Accent? How about a 4G63 in your Hyundai Elantra? Maybe a Beta 2 for your Hyundai Tiburon? Post all questions here relating to transmissions and engines from other makes and/or models, you want to install in your Hyundai.
Screw the BS..........4G63 Swap....need opinions
Old Mar 24, 2002 | 02:01 PM
Agarwal's Avatar
Seen this one guys?
Tib with a 4G63T
Old Mar 24, 2002 | 02:12 PM
Veniston's Avatar
Holy **** how far can he glide on that wing?
eek!
Actually it kind of reminds me of a towtruck in that shot from the rear....
Old Mar 24, 2002 | 02:31 PM
Koreandude's Avatar
hmmm, well, there you have it. It's been done. I guess it wasn't that much trouble or maybe they don't have 350's to swap in instead! rolleyes.gif
Old Mar 24, 2002 | 02:32 PM
FordFasteRR's Avatar
why is the timing belt on the passengers side ?
dont the 2.0L turbo motors from the eclipse have the timing belt on the drivers side??
something is fishy there guys....
or is it just my imagination ?
Old Mar 24, 2002 | 06:16 PM
Red's Avatar
Red
You are correct -- the Mitsubishi USDM 4G63 motor has the timing belt on the driver's side.
That isn't a USDM 4G63 motor, but it could be some other variant that's offered elsewhere. Someone in this thread mentioned the EVO 6 and later engines, which are indeed a similar setup to a 4G63 but are flipped "backwards" so that the timing belt is on the passenger side.
But getting an EVO 6 motor will be expensive... You'll have to ship it from overseas, and likely the one you'll get will be used HEAVILY used and need a rebuild.
Your call I suppose, but the fabrication costs alone will still be at least $2000. And you'll still need the tranny, ECU, wiring harness and you'll still need the rebuild.
Either way it's probably at least a $5000 buildup if not more -- IF you do all the labor yourself.
I'd just as soon keep the Hyundai engine IMO.
Old Mar 24, 2002 | 09:25 PM
Agarwal's Avatar
Yeah anyways, you guys know that ANYTHING can be done, right? You *only* have to put the money down... serious amount of money, most of the time! smile.gif
Old Mar 25, 2002 | 01:09 AM
A mitsu swap is possible with enought time, effort and money. However, for your $5000 to $10,000 that the motor, tranny, axles, ECU and fabrication would cost, you would still have a bone stock mitsu turbo motor cranking out a paltry 200 HP to the wheels at best.
For that same $5000 to $10,000, you could turbocharge your existing motor, replace/upgrade all necessary parts, and replace the ECU with a Haltec/Motec style stand alone engine managment system, and be cranking out something closer to 300 to 600 to the wheels.
Its your money, and your call.
Old Mar 25, 2002 | 02:21 AM
Koreandude's Avatar
I'm just gonna buy a Lancer Evo VII and slap a tiburon badge on it!
Rich
Old Mar 25, 2002 | 10:13 AM
lantraluvr's Avatar
Vehicle: 1999 Elantra
Anything's possible, right? I think the EVO engines have more HP potential, don't you think. I'm planning to place an EVO motor into my Elantra in the future.
Old Mar 25, 2002 | 10:38 AM
Cheuk in Seoul's Avatar
I don't think that the EVO engine has any more potential than the Beta. In fact the Beta is probably a little stronger.
