Hyundai Hybrids Want to drop in a Beta for your Hyundai Accent? How about a 4G63 in your Hyundai Elantra? Maybe a Beta 2 for your Hyundai Tiburon? Post all questions here relating to transmissions and engines from other makes and/or models, you want to install in your Hyundai.
Need help from the Engine gurus
Old Jul 4, 2002 | 12:46 PM
Shwa's Avatar
so if i went with a turbo. i would also have to get pistons and rods, along with a new fuel pump right? or at least an upgraded one. then i would maybe need to get an s-afc. along with what else?
i mean, for me to get a turbo right now. would be in the range of 3800$. my friend custom makes them. but that right there is a price of an engine almost, isnt it?
Old Jul 4, 2002 | 02:16 PM
Veniston's Avatar
If you're looking for real power, an S-AFC won't hack it. Be prepared for 1000+ for a proper engine management system.
And sure, you can get a real nice engine for that price. But then there's the transmission, and the axles. And then the install--custom fabrication and whatnot ramps up towards $10K. Unless you've got a full metal shop to use for free, the costs of shoehorning those suckers in there run up pretty quick.
Shadohh's Avatar
nah, for an engine you will be looking at $5k atleast!!
also, whats that engine gonna give ya? 180? 240? 280?
$3.8k on turbo you got 400hp, easy.
Old Jul 4, 2002 | 02:23 PM
Shwa's Avatar
is that at 10 psi? with changing out the pistons, rods, and fuel pump? i all ready have an exhaust, and would prolly get headers and a full cat back. you are saying that i could almost triple my hp by only that? i dont know that much about cars, but thats a real hefty hike in hp.
Old Jul 4, 2002 | 02:28 PM
rubenz2K1's Avatar
i'm sure you could run more thatn 10psi with low compression pistons and such that are made for higher boost applications.
Old Jul 4, 2002 | 02:35 PM
Veniston's Avatar
Erm, you do realize that you need a turbo manifold, which replaces your exhaust headers?
Also, serious turbos will run at least 1-1.5 bar(14.5-22 psi), which is what the stronger rods are for wink
And I'm not so sure that you could get the tuning in under that $3800 limit. The kit can come in under the wire, but dyno time for the new EMS will run you a bit too.
Old Jul 4, 2002 | 02:38 PM
rubenz2K1's Avatar
<div class='quotetop'>QUOTE </div><div class='quotemain'>Veniston:
And I'm not so sure that you could get the tuning in under that $3800 limit. The kit can come in under the wire, but dyno time for the new EMS will run you a bit too.</div>well he has 10 grand to play with so that should be more than enough. smile.gif
Old Jul 4, 2002 | 02:44 PM
Shwa's Avatar
And I'm not so sure that you could get the tuning in under that $3800 limit. The kit can come in under the wire, but dyno time for the new EMS will run you a bit too.</div>so with the turbo manifold, that will replace my existing headers? so the ones off sr would not be able to handle that, huh? or would they?
right, i got the stronger rods and pistons part.
and the 3800$ would be just for the customer made turbo for my car. the dyno time for me wount be that bad, the would only charge me 50$ per pass.
and what is the difference between regular headers and the turbo manifold?
Old Jul 4, 2002 | 02:47 PM
Veniston's Avatar
*sigh*
The turbo part.
http://www.howstuffworks.com/turbo.htm
Old Jul 4, 2002 | 03:04 PM
Shwa's Avatar
thank you much. that is very helpful. me gonna go home and read it all.
