Hyundai Hybrids Want to drop in a Beta for your Hyundai Accent? How about a 4G63 in your Hyundai Elantra? Maybe a Beta 2 for your Hyundai Tiburon? Post all questions here relating to transmissions and engines from other makes and/or models, you want to install in your Hyundai.
motor mounts
Old Jun 23, 2010 | 08:47 AM
accent_01's Avatar
Vehicle: 01 Accent
Default motor mounts
When doing the beta swap, is it better to get new poly fill mounts or will regular stock ones be fine?
Old Jun 23, 2010 | 10:22 AM
My stock ones have the consistency of Jello. Anything would be better. Poly mounts or fill yours with window weld.
Old Jul 20, 2010 | 05:23 AM
yamaha's Avatar
Vehicle: 2000 Hyundai Elantra
Window weld is a nice cheap alternative.
Old Jul 20, 2010 | 07:03 AM
I used silicone rubber and that worked also.
Old Jul 20, 2010 | 10:06 AM
Bommello's Avatar
Window weld did a good job on mine. Just make sure you let them completely harden before install.
Old Jul 21, 2010 | 08:36 AM
Tak82's Avatar
Vehicle: 1997 RD 4-door
just to let u know, stiffer mounts will transmit more vibrations into the cabin, especially with the a/c on,
do one mount at a time, so you don't have a car with the feeling of the motor bolted to the frame
u can use window weld"urethane"
or flexane which is a liquid that gives better results and reduce air bubbles
Old Jul 21, 2010 | 08:52 AM
JonGTR's Avatar
Do the front/rear first. Then, if you want more, do the sides.
Old Jul 21, 2010 | 12:23 PM
In the case of my car Tak82 you are 100% wrong. My stock mounts were falling apart, and the engine was flopping around, causing severe surging under heavy acceleration. The stiff mounts make NVH levels go DOWN in such a case.
Old Jul 21, 2010 | 11:11 PM
wheel_of_steel's Avatar
i've got 3 stock mounts and one metal mount
holy f*ck vibration. its actually a bad situation to be in, its putting huge stress through that solid mount.
