Hyundai Hybrids Want to drop in a Beta for your Hyundai Accent? How about a 4G63 in your Hyundai Elantra? Maybe a Beta 2 for your Hyundai Tiburon? Post all questions here relating to transmissions and engines from other makes and/or models, you want to install in your Hyundai.
Excel
Old Jan 18, 2011 | 07:36 PM
  #31
Tibbi's Avatar
Holy crap dude! That is amazing!!
I so want one oriented for the Beta
Old Jan 19, 2011 | 11:15 PM
  #32
epinero's Avatar
Vehicle: 1994 Hyundai Excel Coupe
Still waitn on my BC springs and cams to finish up the head but I figured I'd post my steering wheel install to keep things moving in the mean time:
Grant Steering Wheel Install:
Note: When replacing steering wheel remember to disable the horn and unplug the battery to avoid damaging anything.
Stock Steering Wheel:
Removed Center Piece:
Unscrewed Center Screw (marked red):
Note: I took off the steering wheel the old school way, with a hammer. Leave the screw bolted on for this. Position your two legs tightly up against the bottem of the steering wheel. Then hold a hammer against the center screw, then with another hammer carefully strike the first hammer while pulling the steering wheel back with your two legs wedged underneath. This will slowly break the friction and eventually pop out the steering wheel. Be VERY CAREFUL not the damage the center bolt area!!
Steering Wheel Removed:
Grant Adapter Hub Installed w/ Horn Wires:
Grant Steering Wheel Installed:
Help that helps anyone who simply wants a simple visual on installing a steering wheel on an "non-airbag" car...
Old Jan 20, 2011 | 02:19 AM
  #33
iheartmyrd's Avatar
Vehicle: 1998 Hyundai Tiburon
It was my tib that i swaped from auto to manual.
Old Feb 4, 2011 | 05:07 PM
  #34
Jed118's Avatar
Vehicle: Hyundai Pony
Hehe I've got a 4G67 head ported and polished lying under my bed! With a pair of DCOE 45's that were supposed to be attached to it.
Good work, I've got the same block in my Stellar!
Old Feb 16, 2011 | 06:39 PM
  #35
epinero's Avatar
Installed pistons and rods finally, rings gapped n all :biggrin:
Timing side pretty much all set too
Old Feb 19, 2011 | 07:10 PM
  #36
epinero's Avatar
So after finding out my old valves weren't as straight as I hoped I just bought new ones. Spent a well worthed hour hand lapping....
So the head is fully assembled and very releaved...
Head Specs:
Hot Tank + Resurface
3mm Revised Lifters
Graveyard Motorsports 272/272 Cam Shafts
Brian Crower Valve Springs/Titanium Retainers
Fidanza Cam Gears
Anyone curious how I disassembled and assembled the head:
Old Feb 19, 2011 | 07:24 PM
  #37
epinero's Avatar
Heads on the block timed and torqued, almost done :biggrin:
Old Feb 19, 2011 | 09:08 PM
  #38
Keep it up!
Old Feb 19, 2011 | 10:50 PM
  #39
HotBlue02's Avatar
Vehicle: 02 Hyundai Accent
This is awesome, nice to have an X2 owner floating around. There is only one thing killing me, everything is so shiny an new but that motor mount bracket is sticking out like a sore thumb. Other then that its looking great.
Old Feb 20, 2011 | 08:47 AM
  #40
epinero's Avatar
I know lol I've gotta list of stuff I'm gonna have a freind sand blast and thats included!
