Hyundai Hybrids Want to drop in a Beta for your Hyundai Accent? How about a 4G63 in your Hyundai Elantra? Maybe a Beta 2 for your Hyundai Tiburon? Post all questions here relating to transmissions and engines from other makes and/or models, you want to install in your Hyundai.
engine swaps
Old Oct 30, 2009 | 09:22 AM
sharkfx's Avatar
Vehicle: Tibby Fx
Default engine swaps
I see some tibs in Korea that have done Nissan SR20 swaps. I have been saving up and finally bought an SR20 engine and all the components. I dont have a transmission yet and this is what Im trying to figure out. Whats involved with getting it to fit and sit in the tib like the ones in Korea? Im searching for a shop now that will do the transplant. I ordered a stand alone and hope to have that here soon since I know the stock ECU cant be used.
Thank you for the help.
Old Oct 30, 2009 | 09:38 AM
HotBlue02's Avatar
Vehicle: 02 Hyundai Accent
Ahhh! Nissan motor in a Hyundai, that is like blasphemy or something. Good luck with that and keep us informed, it should be a beast.
Old Oct 30, 2009 | 09:40 AM
342Four's Avatar
Vehicle: '97 X3
<div class='quotetop'>QUOTE (sharkfx @ Oct 30 2009, 11:22 PM) <{POST_SNAPBACK}></div><div class='quotemain'>I see some tibs in Korea that have done Nissan SR20 swaps. I have been saving up and finally bought an SR20 engine and all the components. I dont have a transmission yet and this is what Im trying to figure out. Whats involved with getting it to fit and sit in the tib like the ones in Korea? Im searching for a shop now that will do the transplant. I ordered a stand alone and hope to have that here soon since I know the stock ECU cant be used.
Thank you for the help.</div>
front wheel drive sr20 jobby yeah???
cause if it was a rwd then ur stuffed
unless you could get a fwd sr20 manual trans and somehow stuff it all in
you would need custom driveshafts most likely
Old Oct 30, 2009 | 09:41 AM
Whiplash's Avatar
Vehicle: SRT4/Neon SOHC
Ive never seen one personally. But I would think its safe to assume you will need the transmission that goes along with the sr20 as well as the entire wiring harness...
Old Oct 30, 2009 | 09:53 AM
sharkfx's Avatar
Vehicle: Tibby Fx
Wiring will be a nightmare but since Im doing a stand alone it shouldnt be too hard. Im hoping to pick up a couple of transmissions soon for trial and error.
Old Oct 30, 2009 | 10:15 AM
It's not a swap I would have picked personally, but it'll be interesting at least.
Be ready, you've got a big headache ahead of you though.
Old Oct 30, 2009 | 10:23 AM
You should contact this girl and ask her if the shop whos doing her swap has any tips or advice on your swap:
http://www.cardomain.com/id/RG-tiburon
Old Oct 30, 2009 | 01:03 PM
Fintile's Avatar
not a bad idea but i think a 4G63T swap would e easier IMO.
