Hyundai Hybrids Want to drop in a Beta for your Hyundai Accent? How about a 4G63 in your Hyundai Elantra? Maybe a Beta 2 for your Hyundai Tiburon? Post all questions here relating to transmissions and engines from other makes and/or models, you want to install in your Hyundai.
Beta 1 or Beta 2
Old Feb 8, 2010 | 10:22 AM
grind's Avatar
Vehicle: Hyundai Accent
Default Beta 1 or Beta 2
Whats a better engine to drop into an Accent? The Beta 1 or 2? I always thought they were the same for the most part. Is there any reason to choose one over the other?
Old Feb 8, 2010 | 12:04 PM
SUPPOSEDLY the beta 2 has a slightly stronger block, the head design is a little better
but im not sure how the harness connects to the accent harness it might be easier to install a beta 2 engine using beta 1 sensors
Old Feb 8, 2010 | 01:24 PM
It depends on which Accent. A Beta I is better for an X3, a Beta II is better for a LC/LC2. The reasoning is compatibility, the LC/LC2 1.6l ECU will run the Beta II engine. The Beta I ECU will plug into an X3's harness and run the Beta I.
Old Feb 8, 2010 | 05:32 PM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
I would like to note that the LC Alpha ecm runs the Beta2, but your going to give up a good amount of low end torque. Ive seen it running along side a beta swapped accent in my elantra, a dyno on another website, and can feel it driving the thing then driving my heavier beta powered car. It nails the air/fuel so the problem must be timing. So you end up with the same peak hp, but your powerband is smaller. Don't shift to soon, heh.
Old Jun 19, 2010 | 03:13 PM
03hatchetback's Avatar
Vehicle: 2003 Hyundai Accent
and what yrs and makes do the beta 2 come out of.
Old Jun 19, 2010 | 03:28 PM
search is your friend
