Hyundai Hybrids Want to drop in a Beta for your Hyundai Accent? How about a 4G63 in your Hyundai Elantra? Maybe a Beta 2 for your Hyundai Tiburon? Post all questions here relating to transmissions and engines from other makes and/or models, you want to install in your Hyundai.
1.8 vs 2.0 flywheel
Old Jan 25, 2012 | 01:25 PM
accentblurr's Avatar
Vehicle: 2002 Accent
Default 1.8 vs 2.0 flywheel
I finally scored a 2.0 for my accent. Problem is that I don't have the flywheel (stick). I'm curious if anybody can tell me what the difference between the 1.8 flywheel and the 2.0 flywheel. The interchange manual at the junk yard says that they are different. Thanks in advance
Old Jan 25, 2012 | 06:01 PM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
There is a spacer you will need. That can be found on the automatics in between the crank and the flex plate I think. I know the 1.8 is lighter as its missing a good bit of metal on the backside.
Old Jan 25, 2012 | 09:55 PM
https://www.hyundaiaftermarket.org/f...ost__p__541075
