1.8 vs 2.0 flywheel
I finally scored a 2.0 for my accent. Problem is that I don't have the flywheel (stick). I'm curious if anybody can tell me what the difference between the 1.8 flywheel and the 2.0 flywheel. The interchange manual at the junk yard says that they are different. Thanks in advance
There is a spacer you will need. That can be found on the automatics in between the crank and the flex plate I think. I know the 1.8 is lighter as its missing a good bit of metal on the backside.
