Hyundai Hybrids Want to drop in a Beta for your Hyundai Accent? How about a 4G63 in your Hyundai Elantra? Maybe a Beta 2 for your Hyundai Tiburon? Post all questions here relating to transmissions and engines from other makes and/or models, you want to install in your Hyundai.
3.8 and 2.7 bellhousings
Old Jan 17, 2012 | 07:55 PM
ryanmunion's Avatar
Vehicle: 2006 Hyundai Tiburon GT
Default 3.8 and 2.7 bellhousings
Is there any difference in the bell housings on a delta 2.7 and a Genesis 3.8 engine? And also is there any other major differences in these engines other then the common differences in most engines ?
Old Jan 23, 2012 | 10:59 AM
I don't know if the bellhousing bolt pattern has been checked, but I strongly doubt that it is the same.
There are a lot of differences between the 2.7l and 3.8l engines, they're from different engine families altogether. There isn't much in common between the two other than they both have 6 cylinders and run on gasoline. Do you have anything specific you were wondering about?
Old Jan 23, 2012 | 09:05 PM
wheel_of_steel's Avatar
If you felt the need for a big cube tib, you would probably be better off using the 3.8 from the azera. It is at least a FWD engine and transmission.
I've seen a photo of the swap done, with a huge single turbo hanging off the side. It is not a cheap way of going quickly though.
Old Jan 26, 2012 | 07:08 AM
Juanra's Avatar
Vehicle: 1997 Beta Swapped Accent
Is there a FWD manual tranny for the Lambda?
Old Jan 26, 2012 | 10:54 AM
I don't believe so, although I'm not completely sure on the SUV's.
