Rundown on "The Plan".
Old Oct 26, 2001 | 02:57 AM
Red's Avatar
Red
The rally team doesn't really need low-end torque for the same reason that a drag-racer doesn't.... Once you're in the car and moving (and racing) you keep the revs about 3K. If you're racing and you're below 3K, you're inexperienced or you're going 10mph (either way in inconducive for racing) How often do you see a Rally car keep the tires spinning at less than 15mph? (3K in 1st gear)
Low-end torque really only matters for a daily driver. Drag racing? You rev to 3K to launch anyway, maybe a lot more if you're running slicks. Autocrossing? Same thing -- if you're running at less than 3K, it's because you're inexperienced. (or maybe you're driving a huge V8 that redlines at 5K)
All of that, and also the fact that superchargers historically SUCK on the BETA motors. I think Cheuk was telling us on FXTreme that the most powerful SC'd Tiburon he knows of gets about another 20 horsepower more than the most powerful N/A Tiburon he knows of. We're talking only right above 200HP at the tires, at best.
Turbo baby!
-Red-
Old Oct 26, 2001 | 05:25 AM
1: 205/40R17 Kuhmo Ecsta 712s $350
KAAZ LSD, $800
Clutch $450
Labor for Clutch&LSD $500
Alpine Turbo less UNICHIP $1500
Haltec E6K, Sensors, Install, Tuning $1500
440cc Injectors, $350
Fuel Pump $150
Custom Mandrel Bent 3" Exhaust w/Random Cat Con $600
Things you missed.
Blow Off Valve $120 to $200
Stronger Axles $500
Install for Turbo? $1200-$2000
Lower Compression pistions(also stronger) $600
Stronger Rods (As long as you are doing the pistions...) $600
Old Oct 26, 2001 | 08:05 AM
Thinking's Avatar
Yeah, 205/45R17. That's what I meant. I only plan on running 10psi max so I really shouldn't need new internals-yet. I can definitely install the turbo myself (no, really I can). BOV DEFINITELY! What kind do you reccomend? How bad are the axles really? I know that they break if you hook up but this thing will have to be babied in 1st gear and I'm not gonna run drag radials but I will get the axles if I ever (when I) up the boost and/or use DRs. BTW, who makes those axles? Lastly, Random didn't you say that you get 9psi by 2500rpm while using the spacer? I would think that the higher compression and Haltec (as far as optimizing timing and generally making everything work well together) should AT LEAST respond that quickly if not faster-ala VW turbos. I know that they use a tiny K03 for fast response but they also run 9.5:1 compression to enhance response time too. Thanks
Old Oct 27, 2001 | 07:27 AM
The new pistions are to lower the compression rather than the head spacer. My headspacer is slowly weeping oil into my coolant. NOT A GOOD THING!
For 10 PSI you are looking at 225 +/- 10 HP at stock compression levels, That was enough for OnPol to snap an axle. If you are going to be auto crossing, you will be putting similar stress on the axles between cornering/accleration loads.
The Axles are good to 325 HP and are being done by the Driveshaft shop.
the pistions/rods are just an "insurance" bet. the stock pistions limit is 250 or there abouts...by going with stronger pistions/rods you can eliminate that weak point and lower the compression to the point where you don't need the head spacer. A win/win senario.
Old Oct 27, 2001 | 08:24 AM
Thinking's Avatar
I definitely agree on all points but I just don't have more cash on hand and I can't think of anything to cut unless you suppose I should get the axles instead of the KAAZ LSD? BTW didn't OnPol break that axle while using slicks? Anyhoo, I guess I'll have to keep it down to 225hp or less for a while- maybe 8psi?
Old Oct 27, 2001 | 11:58 AM
Onpol was using slicks...and it was at a dragstrip, so hella traction. But...
There is nothing to say that only 200 Hp was needed to snap the axle. Or maybe just street tires and lots of cornering load....
When Onpol's axle snapped, it shreeded his differential. If you snap an axle autocrossing, your KAAZ LSD is going to break into 10,000 Pieces....
Old Oct 27, 2001 | 03:49 PM
Thinking's Avatar
Hella uncool aboot axle snappage! If you think I can actually get the turbo kit for 1500 then that should free up enough change for the axles which sound more and more like a good idea everyday, thank you for pointing that out! BTW, any downside to those axles?
Old Oct 27, 2001 | 04:05 PM
They are a little heavier than the stock axles, but I'll take the strength and weight over 2 peice axles anyday.
The unichip is worth $500, so you should get that money off the price of the alpine turbo kit...but you will then need to spend $1500-$2000 for a HalTec EK6.
