Rich fuel problem FIXED !! READ THIS
Old Mar 7, 2002 | 09:54 PM
FordFasteRR's Avatar
again, it cant damage the stock pump.
Old Mar 8, 2002 | 12:05 AM
Veniston's Avatar
<div class='quotetop'>QUOTE </div><div class='quotemain'>SCCA 01 Elantra:
Cool. But what about my other design and have a totally seperate fuel system for the nitrous?</div>That would involve putting another hole in the fuel tank, I'm not familiar with the physical layout, how easy that would be.
In my systems we quite often do something like this:
A bypass with a check valve, using an automatic shutoff on the pump when it is not pumping.
<div class='quotetop'>QUOTE </div><div class='quotemain'>FordFasteR:
again, it cant damage the stock pump.</div>That's not what I see--when you 'pull' an electric drive faster than the applied current allows it creates electromagnetic feedback. The worst case scenario(and I have seen it happen) is that it could catch fire.
I'm not saying that this is the case, just that it could be given the setup. This could be avoided by shutting off the primary pump when the secondary is on, but then it becomes a fairly significant source of flow resistance. Which is why we use the bypass with check valve.
Unless you have some other explanation I'm not seeing.
