Fuel Gauge all Wonky?
Old Sep 17, 2009 | 08:12 AM
UnnaturallyAspirated's Avatar
Vehicle: 1998 Hyundai Accent
Default Fuel Gauge all Wonky?
Hey all.. just a quick question..
i've read the accent x3 tank fits 45L of gas.
When is the fuel light supposed to come on?
My fuel light trips when the needle hits halftank on the gauge.. but when i goto fill it up.. i've still got 15-18 litres of gas left.
Is the fuel light supposed to come on at half just to let you know you've hit half?
does the light come on when you're actually supposed to be low?
And if so, how do i fix it? do i need a new gauge, fuel pump, or sending unit?
Is the sending unit integral to the FP on these cars?
Old Sep 17, 2009 | 09:29 AM
sending unit is part of the fuel pump module
fuel light turns on when it is LOW im talkin less than a gallon low on every one of the 5 hyundais ive owned
Old Sep 20, 2009 | 11:32 PM
<div class='quotetop'>QUOTE (faithofadragon @ Sep 17 2009, 11:29 AM) <{POST_SNAPBACK}></div><div class='quotemain'>sending unit is part of the fuel pump module
fuel light turns on when it is LOW im talkin less than a gallon low on every one of the 5 hyundais ive owned</div>
i mentioned above, when the light hits low.. i've still got 15-18 litres of gas left in the car. the tank holds 45.
so im pretty sure my car isnt actually low when the light turns on.. so why does it turn on?
Old Sep 21, 2009 | 06:47 AM
your fuel level sender probably is sticking/binding on something
pull the bottom of the back seat out and check out the sender
its very basic just a arm extending from the fuel pump to a plastic float
