camber kits
Old Oct 24, 2010 | 10:04 AM
no_name's Avatar
Vehicle: 2005 Accent GSI
Default camber kits
Has anyone installed a camber kit on their accent? What size camber bolt is required for an LC? Where did you buy them from?
I've got some H&R springs being shipped in for my 05 Accent and after a 1.4" drop my camber will probably be a bit off, plus I want to be able to dial in some negative camber for auto-x in the summer.
Old Oct 24, 2010 | 01:41 PM
Clicky
I will be installing mine in the rear next spring when I put on the ksports.
Old Oct 24, 2010 | 09:07 PM
no_name's Avatar
<div class='quotetop'>QUOTE (187sks @ Oct 24 2010, 03:41 PM) <{POST_SNAPBACK}></div><div class='quotemain'>Clicky
I will be installing mine in the rear next spring when I put on the ksports.</div>
I took a look and they want $108 to ship to Canada so I'll keep looking. Do you know what diameter the bolts you got are? From what I understand I think I'm looking for 10mm cam bolts to replace the stock 12mm bolts.
Old Jan 10, 2011 | 08:53 AM
rival879's Avatar
Vehicle: 2001/Hyundai/Accent GL
I have a 2001 Accent and just picked up these:
Ingalls Engineering Fastcam Camber Adjusting Bolts, P/N: 81250
I'll install them as soon as I feel like working on the car in snow, with an alignment immediately after.
rival879's Avatar
Edit: Sorry newbie duplicate post...
Old Jan 12, 2011 | 08:56 AM
no_name's Avatar
Let me know how it goes. Are you installing on the front only or all 4 wheels?
Old Jan 12, 2011 | 09:09 AM
no_name's Avatar
I just found the 81250 kits on eBay for 14.59 each. Bought a full set. "Not intended for use on cars with modified steering or suspension or for racing purposes"... Meh.
Old Jan 12, 2011 | 10:24 AM
rival879's Avatar
I'm doing one bolt on each wheel. This way I'm sure that the alignment will be a known value instead of the default of a non-adjustable system. I'm thinking about -0.90 front, -0.50 rear. One thing that impressed me about Ingalls is that they seem to have good support and documentation, ie, online installation instructions.
I think that warning is more for the lawyers than a someone with a DD.
