any turbocharger for accents??
Old Apr 22, 2002 | 01:04 PM
TheAzNTempTaTioN's Avatar
Default any turbocharger for accents??
Are there any turbo charger for the 97 accent and if there is where and how much?
Old Apr 22, 2002 | 01:13 PM
Dthomas's Avatar
Yes there is, it will run you around 2,700 us. CAPA, and Chiptorque make one for the Accent.
You would probly be better off getting a 2.0L Beta though.
Old Apr 22, 2002 | 05:27 PM
RPW sells one via Shark Racing. Cost is about $2500 plus install.
dropping in a 2.0L beta would be cheaper, and with mods, would yeild more power.
Old Apr 23, 2002 | 05:00 AM
when you are talking about a 2.0L beta are you talking about a new engine or what?
Old Apr 23, 2002 | 05:22 AM
Red_AGT's Avatar
The 2.0L or 1.8L beta can be found in Elantras or Tiburons. About 140hp and 133 ft-lb at the crank.
The Accent has either a 1.5L alpha or 1.6L. About 95 hp and 92 ft-lb or 105 hp and 103 ft-lb.
Old Apr 23, 2002 | 05:27 AM
will a 2.0L beta fit in the 97 accent though???? and how much does it cost?
Old Apr 23, 2002 | 02:27 PM
<div class='quotetop'>QUOTE</div><div class='quotemain'>TheAzNTempTaTioN:
will a 2.0L beta fit in the 97 accent though???? and how much does it cost?</div>Yes. The motor mounts need to be fabricated or purchased from HVE or RPW. A used beta can be had for as cheap as $500 with ECU, but most go for about $750 to $1000 for a good low mileage unit. If I'm not mistaken, someone at Hyundaiperformance.com was considering the swap, but not sure if they completed it. I also think Dan from KORE did the swap in an accent as well.
Old May 18, 2002 | 10:32 AM
rally_wrc's Avatar
yes KORE did the swap into a 97 accent i believe. its still in devlopment i think.
Old May 18, 2002 | 11:59 AM
dc1238's Avatar
Oh GOD dont give me any more Ideas~!!!!!!!!!!!!!!!!!!!!!!!!!! wink
Old May 18, 2002 | 03:58 PM
Dopeskills's Avatar
Wouldn't a heavier engine throw off the balance of the car?
