any turbocharger for accents??
Old May 19, 2002 | 12:25 AM
MechaniX_034's Avatar
Vehicle: Lancer Evo IX
To some extent yes, Dopeskills...but it's nothing a set of adjustible shocks, pillow ball assys. stabaliser links and a good feel for the handling you want can't solve man...no-one ever said that tuning a car would have no ramifications.
Compromise is part of the game.
Old May 19, 2002 | 01:51 AM
<div class='quotetop'>QUOTE</div><div class='quotemain'>Dopeskills:
Wouldn't a heavier engine throw off the balance of the car?</div>The car is not balanced now. I would only not consider a motor swap on a car that had a perfect 50/50 weight balance, and even then, if you are only altering the weight by 50 lbs. moving the battery to the trunk can offset the heavier engine.
The Beta engine is not significanly heavier than the Alpha (maybe 50 lbs).
Adding that much power either via a turbo charger or a new engine is going to throw off the handling of the car more that the minor weight shift forward of a heavier engine.
Old May 19, 2002 | 11:47 AM
Cheuk in Seoul's Avatar
The 2.0L swap to an Accent is a very nice mod.
I saw a fully tuned stripped NA 2.0L Accent outrun a 400 hp turbocharged SM5 (Maxima body) at the drag races yesterday.
With a nicely built 2.0L Beta and a small shot of nitrous in an Accent would make a very nice sleeper.
Old May 20, 2002 | 05:03 AM
RevKev6's Avatar
the 2.0 really doesn't weigh any more than the accent motor, It probably wouldn't be very noticeable. especially if you put aftermarket lowering springs on it which are stiffer to begin with. but the power difference on the other hand would be very noticeable.
Old May 20, 2002 | 07:19 AM
4doorGL's Avatar
Vehicle: 2009 Hyundai Sonata Limited V6, 2008 Nissan Xterra Off-Road
From the last numbers I saw, the 2.0L Beta with tranny weighes about 100lbs more than a 1.5L Alpha with tranny.
Hell, just the short blocks themselves are a 50lb difference (weighed both of them in my garage).
Old May 20, 2002 | 07:51 AM
accent 1's Avatar
back to the ? you can always use the factory turbo from a scoupe and that will be much less than any turbo kit!
Random with the 1.5 alpha you need engine Trans and compter to do the swap but what about the axles are they going to fit the 2.0 trans???
Old May 28, 2002 | 11:45 AM
dc1238's Avatar
yeah id love to know that also......
