Alpha Questions
Old Feb 11, 2003 | 11:54 PM
Frostbyte's Avatar
Default Alpha Questions
1. This question is related to one of the specifications of the 1.6l Alpha (G4ED). I know bore (76.5mm) and stroke (87mm), but I do not know the connecting rod length. Can somebody enlighten me on what this might be? I cannot seem to find this value on hmaservice.com's webtech.
2. I am a little confused about the 1.5l dohc Alpha engine (G4EK? I notice it is common in Australia). Some sources indicate it is 12 valve, others 16 valve. I realize both may exist. How simillar is the (if it exists of course) 1.5l 16v dohc to the 1.6l 16v dohc?
Old Feb 16, 2003 | 10:36 PM
VALKYRIE YB70's Avatar
I may be wrong, but I have always been under the impression that the SOHC Alphas were 12-valve & the DOHC are 16-valvers.
Old Feb 16, 2003 | 11:28 PM
Frostbyte's Avatar
<div class='quotetop'>QUOTE</div><div class='quotemain'>VALKYRIE YB70:
I may be wrong, but I have always been under the impression that the SOHC Alphas were 12-valve & the DOHC are 16-valvers.</div>No, I think you're completely correct. Webtech has some improper info that causes some confusion, and I've found other pages that cause some confusion.
Go to webtech, select Accent, 1998 or 1999, 1.5l DOHC, go to Engine Mechanical System, General, Specifications, and it lists the engine as a 12 Valve. After a closer look, it's just an error on Webtech, and that is the link to the SOHC engine (page id 9419)
if the 1997 dohc cam specificaitons contain a typo as I now believe it does, both cams are identical for the 1.6 and 1.5 dohc engines.
Old Feb 17, 2003 | 02:19 AM
The only way to find Con-Rod Length is to remove a con rod and measure it, or get your hands on a "spare" or "new" unit and measure it.
Con-Rod length is usually NOT in the published specs of a motor.
Old Feb 18, 2003 | 11:48 AM
Suprgtrs_man's Avatar
The rods are the same between the DOHC Alphas. Also the cams are different. The only difference between the new 1.5L & 1.6L DOHC motors are the pistons & crank.
