01 accent project continued.....
Old Jul 30, 2002 | 04:08 AM
Accent_Racing's Avatar
Default 01 accent project continued.....
Ok Random I did what you said. I am looking for a target HP of 250+. It will need to be a daily driver with the occasional drag abuse just for fun. Since I was told a V6 is not resonable I am looking elsewhere. I saw Mazda has a 1.3L 250hp engine coming out. Is there a spacific engine I could put in that would bring me toward my goal? Any help would be appreciated.
Old Jul 30, 2002 | 04:11 AM
QS's Avatar
QS
God why can't Hyundai make some thing like this?
Old Jul 30, 2002 | 04:12 AM
Red's Avatar
Red
This is a 2001 Accent right? Why not just drop a BETA in it? You can pick 'em up cheap (like $500 for a longblock with low mileage), it ALMOST is a bolt-in on the newer Accents, change out some fuel lines, ECU and wiring and you've got yourself a 140HP Accent that's 100% daily driveable right there.
Spray a direct-port 100 shot and you've got the race version on-button. Cake.
You could probably do the whole setup for around $3K (assuming you do your own labor)
Old Jul 30, 2002 | 04:21 AM
Red's Avatar
Red
I didn't see the comment on the 1.3L engine...
You failed to realize (or comment) that this is a ROTARY engine, and is not a piston engine. Rotary engines are two orders of magnitude more efficient (displacement vs power output) than a 4-stroke piston engine. Because of the entirely different concept of a rotary, the displacement vs power *argument* cannot be applied.
Old Jul 30, 2002 | 04:27 AM
yes it's an 01 accent.
[B]You failed to realize (or comment) that this is a ROTARY engine, and is not a piston engine.
I just didn't know. I am still learning about cars in general. 140 is not bad but I want more. hehe no **** huh? Money is not my problem. Insurence is. That is why I am keeping my accent, other wise I would buy an Eclipse GSX like I want to. So expense is nothing. Thanks for your help so far. Keep it coming guys.
Old Jul 30, 2002 | 06:03 AM
Shadohh's Avatar
Red is correct, and just about everyone else should be telling you the same.
Drop a BETA into the accent. Get use to it first. You all want more power, but you must remember, you are putting more power into a smaller car.
Its going to be alot faster then a tiburon, its about 500 pounds lighter.
Might I also mentiopn BETA is a better platform to get more power. Turbo Kits, S/c Kits, are all available for this engine in a more cheaper and easily obtainable form.
See how you like 140hp before you start asking for more.
Old Jul 30, 2002 | 11:21 AM
Zeebone's Avatar
Vehicle: 2007 Tib
Everyone always talks aboutthese betas, is beta just a term for an Elentra or Tiburon 2.0? Why is it called *Beta*.
Can I just drop a standard US 2001 Tib engine into my 2K1 Accent? Would this be called a beta swap?
Old Jul 30, 2002 | 12:01 PM
Red_AGT's Avatar
<div class='quotetop'>QUOTE</div><div class='quotemain'>Zeebone:
Can I just drop a standard US 2001 Tib engine into my 2K1 Accent? Would this be called a beta swap?</div>Yes it's the engine code...
Alpha = Accent 1.5 sohc, 1.5 dohc, 1.6 dohc
Beta = Tib, Elantra 1.6, 1.8, 2.0
Delta = V6 found in Tib, Sonata, Santa Fe
Theta = I don't know ... hehe
Chasis Codes
X3 = 95-99 Accents
LC = 2000-2002 Accents
GK = 2003 Tibs
Can't remember the rest, but I have it writen down somewhere at home. smile.gif
