Wierd electrical issue
Old Jan 22, 2013 | 05:49 PM
bigfishmoney's Avatar
Default Wierd electrical issue
My tail lights will not shut off when i turn off my car, the instrument cluster lights are on as well, nothing shuts off, this will drain my battery i think..this started after i replaced my turning signal assembly, theres a single white white i did not see fit to use on the turning signal assembly wire harness.. is there soemthing i can do with this single white wire to make this compatible with my car cause obviously it is not compatible with it
Old Jan 22, 2013 | 06:04 PM
If electronics don't shut off with the switch, then the switch (or a relay) is bad, or your wires are shorted in a way that makes them always be "on" which could have happened in the accident.
Old Jan 22, 2013 | 07:08 PM
could my ecu be ruined?
Old Jan 22, 2013 | 08:48 PM
Anything is possible, but that seems unlikely just now. Check the wires, switches and relays first.
