bigfishmoney |
01-22-2013 05:49 PM |
Wierd electrical issue
My tail lights will not shut off when i turn off my car, the instrument cluster lights are on as well, nothing shuts off, this will drain my battery i think..this started after i replaced my turning signal assembly, theres a single white white i did not see fit to use on the turning signal assembly wire harness.. is there soemthing i can do with this single white wire to make this compatible with my car cause obviously it is not compatible with it
