Stripping TPS Screws
Old Apr 23, 2011 | 09:19 AM
Ben M's Avatar
Thanks for the advice guys! I don't have any cutting tools so I ended up hammering a flathead screwdriver into the screw to make a new slot and this worked fine. Now I just have to find a good TPS, because the one I picked up at the junkyard doesnt work. Thanks!
Old Apr 23, 2011 | 09:41 AM
The TPS screws are very soft. SO make sure you use a good screwdriver/bit and make sure you PRESS IN as you turn. If you're just turning, you will round off/strip the threads.
Next time TEST the TPS in the junkyard before you bother to remove it!
Old Apr 26, 2011 | 03:23 PM
epinero's Avatar
Vehicle: 1994 Hyundai Excel Coupe
Yea it's always a good idea to bring a digital multimeter to the junker to test simple things like that, sux payin for something tht doesn't work
Old Apr 27, 2011 | 06:28 AM
StrikeEagle's Avatar
Don't forget too, lefty loosey, righty tighty!
Old May 16, 2011 | 02:17 AM
compoundedLC's Avatar
Vehicle: 2001 Accent
next time use needle nose vise grips, those little screws are no match.
