Need Help ASAP w/ timing belt
Old Jan 21, 2002 | 05:30 AM
ILL_ANTRA's Avatar
Default Need Help ASAP w/ timing belt
I can't get the crankshaft pulley loose to get to the bottom part of the timing belt cover. I've been trying for about 1/2hr and it won't budge....any suggestions...i got 1.5hrs before it gets dark and i hope to be done by then.....
Old Jan 21, 2002 | 05:38 AM
Chris H's Avatar
Use a long breaker bar that reaches the ground and crank over the engine.
Old Jan 21, 2002 | 05:39 AM
Chris H's Avatar
If you don't have one that reaches the ground prop it against the lower control arm.
Old Jan 21, 2002 | 06:16 AM
ILL_ANTRA's Avatar
I'm kinda scared about doing that. i already removed most of the pullies and i don't think i would work....
Old Jan 21, 2002 | 07:48 AM
Chris H's Avatar
It works, I've done it before.
Old Jan 22, 2002 | 09:38 AM
ILL_ANTRA's Avatar
Thanks for the help...Norubit
