BBTB Installed - Problem - HELP!
Old Oct 27, 2002 | 08:52 AM
pahaake's Avatar
Default BBTB Installed - Problem - HELP!
All-
I installed my Tigerlilly 60mm tb today, reset my ecu and went for a drive (this on the V6). Initially it seemed great - but once I revved the motor the idle is now floating between 1500 and 1800 rpm and sometimes revving up to 3000 all by itself. When driving it feels like the throttle is sticking too. It's not mechanical - so I'm guessing it's the TPS. It came with one already installed, and it looks brand new - like they took an OEM TB and bored it. Suggestions? If I can't fix it tonight - I'm just going to put my stock TB back on.
TIA
Old Oct 27, 2002 | 09:08 AM
PB's Avatar
PB
Just swap your original TPS on to the the new TB first, before swapping the whole unit back. That way you can see if the TPS is really the problem or if it's cable related.
Old Oct 27, 2002 | 11:14 AM
Ego's Avatar
Ego
Check the cable tension: make sure it's not too tight and holding the throttle open, make sure the cable is still running the same path, no kinks or tight bends.
Check for vacuum leaks: Check every single hose and clamp and bolt, any leak near the TB can cause erratic idle.
Then consider TPS and other things that may require more work wink
Old Oct 27, 2002 | 01:54 PM
pahaake's Avatar
Tried swapping the TPS - same thing (and triple checked everything). Swapped the old TB back in and the problem disappeared. I know the performance is better when you match the intake manifold - but the larger bore of the tb wouldn't cause the problem would it?
Old Oct 27, 2002 | 11:10 PM
Brendan's Avatar
sounds like a vaccum leak somewhere.
Old Oct 27, 2002 | 11:31 PM
JonGTR's Avatar
Install the BBTB and make sure the butterfly is completely shut when at idle.
Old Oct 27, 2002 | 11:57 PM
Jmontigny's Avatar
Vehicle: 02 Elantra
What is the deal with the ISC motor? Did it come with the new T/B or did you have to swap it over?
