Rotora Brake Kits...
Old Feb 12, 2005 | 07:13 PM
  #41
Johns03Tib's Avatar
<div class='quotetop'>QUOTE (tibby01)</div><div class='quotemain'>the sonata rotors were bigger. there was a picture of them underneath the stockers, and you could definately see the difference. make sure you are searching for the sonata rotors made for vehicles equipped with abs john.</div>
Hmmm, this is what I used.....
http://hmaservice.com/webtech/iindex.asp?i...7324#_394887324
I FIXED THE LINK!!!!!! TRY AGAIN!
Old Feb 12, 2005 | 09:42 PM
  #42
http://www.rdtiburon.com/forum/showthread....t=sonata+rotors
Old Feb 13, 2005 | 07:21 AM
  #43
Johns03Tib's Avatar
<div class='quotetop'>QUOTE (tibby01)</div><div class='quotemain'>http://www.rdtiburon.com/forum/showthread....t=sonata+rotors</div>
Hmmm, well alright....I stand corrected. I'll look up the 04's with ABS....
*EDITED FOR DOUBLE POST*
http://hmaservice.com/webtech/iindex.asp?i...1172#_394891172
.....still scratching my head....
*EDITED FOR TRIPLE POST. JOHN, ONE MORE DOUBLE POST AND I WILL BAN YOU FOR 10 DAYS. USE THE FREAKING EDIT BUTTON*
<div class='quotetop'>QUOTE (ArcticChill)</div><div class='quotemain'>Same. Wow. Disappointing. Technically, the newer stock Sonata rotors were supposed to be bigger...like 11.1 inches or so...same size as GK rotors. Bah. You know if they can do a custom one of 11"-12" diamter rotors with the same specs as the RD Tib rotors (minus the diameter, of cours)?</div>
You know, it does not matter the exact size of the Sonata rotors. If you want to upsize your front rotors, keep in mind you have to upsize your calipers as well.
With that in mind, did you have a caliper in mind already? If we can find you a 11" 4-lug rotor, you'll need to buy a GK caliper.
Might be easier to just get OE RD replacments....I'll check on the 4-lug still for you.
Old Feb 13, 2005 | 07:38 AM
  #44
Johns03Tib's Avatar
Old Feb 13, 2005 | 07:42 AM
  #45
Johns03Tib's Avatar
Old Feb 13, 2005 | 08:16 PM
  #46
Arctic Seraph's Avatar
<div class='quotetop'>QUOTE </div><div class='quotemain'>You know, it does not matter the exact size of the Sonata rotors. If you want to upsize your front rotors, keep in mind you have to upsize your calipers as well. </div>
Yeah, I know my brakes. XG350 2-piston ones are being used with hopefully a larger rotor. That's why I asked about the Sonata aftermarket OE replacement ones, because they technically should be bigger than the stock RD ones. The Tib stock ones would be a wee bit small for the larger caliper, hence why I asked. If an 11"/12" rotor that fits onto the RD Tib exists, then if you could find out, that would be awesome.
Old Feb 13, 2005 | 11:30 PM
  #47
Yeah doode, the 04 Sonata ABS rotors are 4 bolt, just like ours, and fit PERFECTLY.
They are also 11 Inch.
Only reason Kspec.com isn't selling a OEM BBK is the weight of the rotors.
Old Feb 14, 2005 | 07:17 AM
  #48
Johns03Tib's Avatar
<div class='quotetop'>QUOTE (ArcticChill)</div><div class='quotemain'>Yeah, I know my brakes. XG350 2-piston ones are being used with hopefully a larger rotor. That's why I asked about the Sonata aftermarket OE replacement ones, because they technically should be bigger than the stock RD ones. The Tib stock ones would be a wee bit small for the larger caliper, hence why I asked. If an 11"/12" rotor that fits onto the RD Tib exists, then if you could find out, that would be awesome.</div>
Gotcha....so you have a set of XG Calipers...I'll keep looking for some 11" 4 lug rotors for u.
Old Feb 14, 2005 | 12:57 PM
  #49
<div class='quotetop'>QUOTE (Johns03Tib)</div><div class='quotemain'>Gotcha....so you have a set of XG Calipers...I'll keep looking for some 11" 4 lug rotors for u.</div>
Danke. laugh.gif:
Old Feb 14, 2005 | 07:53 PM
  #50
i just checked brembos site, and they dont have blanks for the 04 sonata with abs, or anything larger than the rotors on a rd tib for that matter.
