Affordable Custom Lowering Springs For Autox And Drag.
Old Jun 20, 2006 | 04:27 PM
the harder the better!
(thats what she said)
struts arent that hard to swap anyways you can swap them in before a race
then swap out
Old Jun 20, 2006 | 07:45 PM
robboser's Avatar
I posted up before that these springs will befor autoX and Drag guys. biggthumpup.gif
I am trying to get around a 350/300 spring rate with a 1.2 " drop
Old Jun 21, 2006 | 10:06 AM
JonGTR's Avatar
Honda "drag" racers are going with 1000lb Skunk2 springs. But that's for track/drag only. They say that 350-400 is good for the daily driver.
http://www.honda-tech.com/zerothread?id=964109
Would be nice to have a set of 350lb springs in a package set of 4. And then be able to buy a set of 2 1000lb springs for the rear.
Old Jun 21, 2006 | 04:16 PM
robboser's Avatar
Yeah but what kind of WHP numbers are they seeing?
How stiff do you guys want them? As I said before, these are custom so we can make them whatever you want if there is enough interest
Old Jun 21, 2006 | 04:22 PM
im with whatever jon wants LOL
Old Jun 21, 2006 | 08:19 PM
jon- set the numbers mang... i need some springs.
Old Jun 21, 2006 | 08:35 PM
JonGTR's Avatar
<div class='quotetop'>QUOTE (JonGTR @ Jun 21 2006, 11:06 AM) <{POST_SNAPBACK}></div><div class='quotemain'>Would be nice to have a set of 350lb springs in a package set of 4. And then be able to buy a set of 2 1000lb springs for the rear.</div>
But I've never used an aftermarket set before, so I don't know how harsh they are as is. I'm sure we could call Eibach and ask them what theirs is rated. Then add a little more.
Old Jun 21, 2006 | 09:22 PM
well the eibachs are actually pretty soft IMO...
Old Jun 22, 2006 | 09:59 AM
JonGTR's Avatar
Actually, the Eibachs are VERY soft!!!! I just got off the phone with them.
The guy only had the info sheet on the rear set. They come straight from Germany.
It's a dual rate spring. The initial rate is 85lbs/inch. The second rate is 159lbs/inch.
I can't imagine that being much better than stock. Just lower.
Old Jun 22, 2006 | 12:11 PM
They are better though. Or maybe it's just the strut combo that is.
Try to find out what the HKS springs are rated.
I know they are labeled as "HARD".
