Holiday Specials
Old Dec 6, 2002 | 03:03 AM
  #21
98tib's Avatar
Vehicle: 2005 tiburon gt
that would require taking the tranny off than putting it back together than taking it back apart to install new parts. isnt there any other easier way?
Old Dec 7, 2002 | 03:32 PM
  #22
Does anyone know if those wires will fit under the stock wire cover?
Old Dec 8, 2002 | 03:05 AM
  #23
SPIKE's Avatar
Old Dec 8, 2002 | 04:43 AM
  #24
Shadohh's Avatar
unsheathed fit
sheathed dont fit.
Old Dec 9, 2002 | 05:38 AM
  #25
Jmontigny's Avatar
Vehicle: 02 Elantra
I just got off the phone with Fidanza they do make two seperate Flywheels for the 2.0L Beta's
193141 for post 6/99 with the 35mm mounting
193241 for pre 6/99 with the 41mm mounting
The 193141 will fit 6/99 and newer Elantra and Tiburon including the 01-03 Elantra and 03 Tib with 4Cyl
The 193241 will fit the 6/99 and older Elantra and Tib with 2.0L. I can't say for sure if it will work on the 1.8L however.
Old Dec 9, 2002 | 06:23 AM
  #26
Red's Avatar
Red
According to some information from FXTreme, the 1.8L and 2.0L engines (pre-06/99 that is) use a different part number on the flywheel BUT are cross-compatible.
The 1.8L used a slightly lighter flywheel design than the 2.0L did, hence the seperate part number. The bolt pattern and mounting surfaces are identical.
Old Dec 11, 2002 | 10:30 PM
  #27
Snowman's Avatar
We now have both for sale,
Sorry for the delay guys
Old Dec 12, 2002 | 12:50 AM
  #28
KillerShark68's Avatar
Vehicle: 2007 Tiburon
RED??? Question? Is the stroke the same? On both 1.8 and 2.0 and could the 1.8crank than be used without flaw in a 2.0 block?
RED????? do ya know?
[ December 12, 2002, 07:50 AM: Message edited by: KillerShark68 ]
Old Dec 12, 2002 | 01:18 AM
  #29
Red's Avatar
Red
Bore is the same, block is the same, bot stroke is not. With the same block but shorter stroke, this necessitates longer rods.
What does this have to do with flywheels?
Old Dec 12, 2002 | 02:38 PM
  #30
When does the Holiday Special Prices end?
