Weak headlights
Old Jan 20, 2005 | 08:47 PM
MasterJ51503's Avatar
Default Weak headlights
am I the only person who has the weakest headlights in the world? Ive replaced my headlights several times but still have the same problems.
I have an 01 tib... i get 5 feet of light maybe less... is this an electrical problem or do tibs just have weak headlights?
Old Jan 20, 2005 | 08:49 PM
Kit-Fox's Avatar
ok, maybe i sound like a Mod now, but dude, this was discused in tons of therads, umm, i have the best headlights ive seen on most cars, i have a 2000 Tib and ive actuayl tested the lights out side by side with other cars, the original aligment sucks, u have to realign them, if u do it right hten u can have excelent ligthing, not crappy, also HID help
Old Jan 20, 2005 | 08:50 PM
CyberShark's Avatar
That's a common problem Master (I never thought I would be calling anyone that)
Old Jan 20, 2005 | 08:53 PM
how would you go about re-alligning your headlights?
Kit-Fox's Avatar
dudes? on original on my tib i agree i had a problem with it, then i realigned them realy well, and it helped out alot, then what i did next is i got HID's, and that helped out ALOT ALOT LOT LOT, its realy worth it, i got like 15$ for the low beams, and $15 for the high beams, on ebay, its worth it, at least for the low beams, it totaly chagnes the look of the car at night, make sure you try realigning the lights.
Old Jan 20, 2005 | 08:54 PM
Tibbychick's Avatar
^^stop trying to be a mod. Headlights blowing out constantly has been discussed before yes, but this sounds different. I would say upgrade to a brighter headlight like Silverstars, or even invest in an HID kit because those last for a very long time. It also sounds like your voltage might be low...maybe check your spark plugs and wires, and your battery too. Maybe you're just not getting enough power due to a power loss somewhere.
Old Jan 20, 2005 | 08:56 PM
yes, my headlights blow out constantly... commonly on the right side... but this is common i have learned... but i just need to learn to re-allign my headlights... then im good to do
Old Jan 20, 2005 | 08:57 PM
Kit-Fox's Avatar
wtf? tick off, btw, congrats on getting 1000 posts, 900 of thsoe beign complaining about me, i try to say something serius for once and your all over me like stink on a fish, jeez, as i was saying umm, i could write a DIY but its pretty simple, behind the lights inside the engine bay are 2 gray caps on each side, look around thier for something you can adjust, i think its screws, u might need a screw driver, if u want ic an check for you.
Old Jan 20, 2005 | 08:59 PM
Tibbychick's Avatar
dont tell me to "tick off" I was simply telling you to leave the moderating to the mods. If I had thought that this topic had been discussed before then I would have locked it.
Old Jan 20, 2005 | 09:01 PM
TibRacer01's Avatar
Do not get the Silverstars!!!
I have ran into the same thing and I figured that the Silverstars would solve the problem and they were the dimmest lights I have ever used!
