Help with HIDs
Old Oct 4, 2005 | 10:22 PM
long's Avatar
thanks for the split.
i dunno why it didnt work today though? it must be the dirt or something i guess. ima take a voltmeter and check it out. if it has good readings then there must be something im missing.
im also going to try the driver side tom. if it works there then i know what to do. i think. lol
Old Oct 10, 2005 | 01:45 PM
Uneek's Avatar
Im a little confused? Why did you cut up the kit? It's a plug and play system. All you had to do was remove your stock halogen bulbs and then connect a few supplied wires to the ballast and bulb and thats it.
Could you post pics of what it is that you did?
Old Oct 10, 2005 | 04:09 PM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
long you didn't get one of the Halo systems did you?
I think he is talking of another kit Uneek. As explained earlier, he was given a relay to use for the passenger side lights only and then run a wire over to the Driver side light.
Old Oct 10, 2005 | 05:16 PM
long's Avatar
^^^ silver has it right.
i dont have the halo kit. i have another kit purchased a couple of years ago that came with a relay.
a description of the wiring is above.
Old Oct 10, 2005 | 11:34 PM
Uneek's Avatar
QUOTE (long @ Oct 10 2005, 03:16 PM)
Old Oct 11, 2005 | 12:23 AM
Sean's Avatar
don't know if it will help or not but when I have wired now 2 HID kits on my Tib...I found the black wire is not negative but positive and the white is negative...stupid if you ask me...had to rewire both kits to get them to work...how stupid is that?
Old Oct 11, 2005 | 12:36 AM
'treezy's Avatar
black IS negative and white positive, it's just that one some HID kits they don't wire the clip correctly and the car's connection is in fact backwards. so you have to remove the wires fromthe clip and switch them (because it only goes in one way).
Old Oct 11, 2005 | 12:48 AM
long's Avatar
you're talking about the wires from the hid kit or the wires inside the headlight?
Old Oct 11, 2005 | 01:38 AM
'treezy's Avatar
i'm talkin about wires from HID
