S-AFC wiring diagram / hints or experience
#21
{"Blue Wire Mod."} [ To read the O2 sensor voltage, scroll down to and select the "etc." menu. Select the "Sensor Check". Of the three readings, O2 voltage will be the middle one (#2.] This is from RRE's website. I give them credit.
#23
Vehicle: 1997 accent L
you'd probably want to be on the dyno to make sure that 1) you are testing under the same circumstances consistantly and 2) make sure you aren't losing power.
