Which one is better?
QUOTE (Mad-Machine)
if you are going to change the timing belt too.. definatly go with the crank pulley. You need to pull the stock crank pulley to change the belt.. so it is actually NO extra work.
I have the unorthodox racing crank pulley.. got it from somebody on this site.
Yeah you are all right!.......kspec....
Did you feel the diference with only the crank pullley???.... any gains in time in the 1/4??
in what range is the better gain you felt.......... and for last.. you got the racing crank pulley.. how different is from the underdrive pulley??
as I have never raced my Tib... it is a back roads burner... I cannot tell you a thing about the 1/4 mile. I can say the engine was easier to rev.. it became a more eager partner to dance with... so far I am on 25,000 miles on the underdrive crank pully and the car shows no problems with not having the harmonic damper
QUOTE (sharkev)
ok... so is in fact a good mod, right?.... now I dont know what would be the better between this pulley and a 1.8 cam!......?
thanks
thanks
Both give you around 2horses to wheels..I would go with the cam first, but that's just me..the cam buy itself will be cheaper then a SR pully set
ohhh ok... that what makes the difference.....
and yes the cam is cheaper than the pulley.... but correct me if I´m wrong, the pulley would give in some way better MPG than stock?? something noticeable??
And the cam would I get worse MPG?? or its nothing Noticeable with these mods?
