OBD 2 Question!!!!!!!
Old Nov 14, 2001 | 01:10 PM
2 UNIQ's Avatar
Default OBD 2 Question!!!!!!!
I'm not computer literate so please bare with me in what im trying to say.
Ok i installed the OBD2 software from my PC and followed the instructions Alex gave me.I entered the software ID number and went through.I followed the instructions and it said its recommended for seperate directorys and i did.I opened up a new folder for all 8 Sample Scans and put them in that folder.Now there is a Total of 22 files?
I copied everything on a Disc so i can install it into my Laptop.I installed it into my Hard drive and it doesnt allow me proceed?
When i open the Obd2.exe file it says "Your Vehicle folder C:/Windows/Desktop/OB2/Noconnect.Log is gone". Then when i press OK,it displays "Put Object to undefined item". What does this mean which object?
Please Help me !!
Old Nov 14, 2001 | 01:36 PM
Viper966's Avatar
umm i wouldnt burn everything on a cd from ur comp to ur laptop, i would install it the same way u did on ur desktop as u woudl do on ur laptop, from the original install disk
Old Nov 14, 2001 | 10:05 PM
Copy the Noconnect.Log from your desktop to your laptop.
That should solve the issue.
BTW...You might want to create a folder called ODB2 or SCAN TOOL off the C: drive rather than off the desktop. The more crap you put on your desktop, the slower your computer is.
Old Nov 18, 2001 | 03:12 PM
2 UNIQ's Avatar
I have the Scan tool up and running but im really confused on how to use it.How do you read it and get rid of the CEL.
Where can i get instructions?
Old Nov 18, 2001 | 08:48 PM
Iago's Avatar
Read the help and readme.txt files that come with the software. That answered about 95% of my questions on how to use the program. The rest, either go to the odb2.com website and look around, email the maker, or post them here. smile.gif
Old Nov 21, 2001 | 09:11 AM
2 UNIQ's Avatar
Ok im trying to get use to this scan tool.Its all new to me.
When i scanned my car for codes i pressed the request button no codes.On the Status folder it says YES to misfire.Anyone has this problem?
How do i check?
Old Nov 21, 2001 | 09:55 AM
Iago's Avatar
How'd you hook up?
It seems to be a little particular about the order of events...here's what I've found gives the most success:
Have a Kleenex handy.
With the car off, turn the key to "acc" or "on."
Plug in and connect to the ECU.
Start the car.
Request codes.
Use the Kleenex for the tears of joy that well up in your eyes as data starts flowing into the parameters. It's a feeling not unlike the one at the end of Twister, when the team finally gets Dorothy 3 to work right.
Of course, I'm still a newbie to the software. I've done maybe all of three or four logs since getting the patch cable. It's still quite fun, though...learning a LOT! smile.gif
Old Nov 21, 2001 | 11:23 AM
2 UNIQ's Avatar
I was also trying to scan my TPS,MAF and other sensors but cant figure out how to test them.
Also the missfire problem Going crazy GRRRRRRRR
Old Nov 21, 2001 | 03:28 PM
Iago's Avatar
They are in the Scan All or whatever option.
They are also available for display on the virtual dashboard. Double click on a gauge, and it gives you the window for selecting what is displayed in which slot. EVERYTHING monitored is listed and available for show....TPS, MAF, IAT, Load, Spark Advance, etc etc etc...
Let us know if you're still having problems, and we might be able to help troubleshoot more.
Old Nov 22, 2001 | 02:22 AM
I'm writing up an OBD-ii guide. I should have it done by sunday. I'll post it up for download.
