Msd dis 4
Old Nov 13, 2015 | 12:38 PM
  #21
patuner11's Avatar
Vehicle: 2000 hyundai tiburon airram zex direct port nitrous outlet standalone fuel cell obx light weight pulleys obx crank pulley fidanaz cam gear 1.8 set up msd dis 4 fidanza flywheel act 6puck non sprung clutch lowering springs m/t drag radials much more much more to come
n 063.png msd dis 4 6215
Old Nov 13, 2015 | 05:13 PM
  #22
i8acobra's Avatar
Vehicle: '14 Ford F-150
Originally Posted by JonGTR
Yes, you can run the DIS4. I did for several years and the standalone had nothing to do with it. I had it on the car before the standalone. The DIS is only an ignition amplifier. Doesn't do anything else but that and retard timing.
What's the point of a DIS 4 without a stand alone? The factory ignition only has 2 channels. That's only 2 trigger wires. You're going to run wasted spark because you're always going to fire 2 coils. I don't see how or why you would use a 4 channel ignition system if you only have 2 channels.
Old Nov 13, 2015 | 09:17 PM
  #23
patuner11's Avatar
All I need is an Msd dis to pull timing for nitrous. It can be a dis 2 or 4 or whatever as long as it works for what I need. This one must be bad.
Old Nov 16, 2015 | 07:28 AM
  #24
JonGTR's Avatar
1. Because the DIS is an ignition amplifier and enhances the factory ignition, even on a factory ECU.
2. Because it will retard ignition. (I used gobs of nitrous back in the day.)
3. Because you can run a 4-COP on the factory wasted spark system and get them to perform better with the DIS.
4. Because I got a great deal on the DIS 4, and it does the same job a DIS 2 would, even on a factory twin coil system.
Old Nov 16, 2015 | 04:40 PM
  #25
i8acobra's Avatar
So, what you're saying is there's no reason to run the DIS4 over a DIS2 other than that you got a good deal on it.
Here's my recommendation... Sell or return the DIS4 and get a DIS2. It will be much easier to install.
Old Nov 16, 2015 | 04:55 PM
  #26
JonGTR's Avatar
So it's too hard for you to understand that you just leave out the 2 extra trigger wires?
Sounds about right for today's "trained mechanic".
Old Nov 16, 2015 | 05:38 PM
  #27
i8acobra's Avatar
You sound like a typical customer... "I bought this part that's not really what I need, but I got cheap. Can you make it work?"
Old Nov 16, 2015 | 11:08 PM
  #28
patuner11's Avatar
I tried everything to make this msd work has to be bad. I called msd ask they claim msd dis 2 are 4 will not work for are cars I told them many people have done it they just said no way they did . I even seen old msd posted saying they do work very strange
Old Nov 16, 2015 | 11:19 PM
  #29
patuner11's Avatar
what I ran a month ago 125shot stock timing c25 in my fuel standalone 112oct in the tib progressive controller 1.8 setup lots of extras
Old Nov 16, 2015 | 11:23 PM
  #30
patuner11's Avatar
right line
File Type: jpg
