Msd dis 4
Old Nov 12, 2015 | 05:32 PM
i8acobra's Avatar
Vehicle: '14 Ford F-150
I ran the dis2 because it's my understanding the dis4 can't be controlled by the stock ECU. You need to run a stand alone ECU.
Old Nov 12, 2015 | 05:47 PM
patuner11's Avatar
Vehicle: 2000 hyundai tiburon airram zex direct port nitrous outlet standalone fuel cell obx light weight pulleys obx crank pulley fidanaz cam gear 1.8 set up msd dis 4 fidanza flywheel act 6puck non sprung clutch lowering springs m/t drag radials much more much more to come
Do you think a dual tach adapter will work? Its my understanding from reading the old posts that this will work.But according to Jon I don't need this.
Old Nov 12, 2015 | 06:03 PM
patuner11's Avatar
Jon I know the violet and yellow wires are grounded but what about the brown/violet and brown/yellow wires? That's the only two wires I did nothing with.
Old Nov 12, 2015 | 06:10 PM
i8acobra's Avatar
The tach adapter is to make the tach work on cars that use the coil signal to run the tach. If your tach works, you don't need a tach adapter.
Old Nov 12, 2015 | 07:16 PM
patuner11's Avatar
MSD says the tach adapter is for misfiring or non run situations. Doesn't say anything about for when the tach doesn't work.
Old Nov 12, 2015 | 07:21 PM
i8acobra's Avatar
From MSD's website:
"If, after installing an MSD Ignition Control, your taÂ*chometer, fuel pump relay or electronic fuel injection (in foreign vehicles) doesn’t operate correctly, your apÂ*plication may require a Tach Adapter. This is due to the trigger signal not being strong enough to trigger both the MSD and the factory’s components."
I didn't need one in my '01 Tib.
Old Nov 12, 2015 | 09:20 PM
patuner11's Avatar
From MSD's website:
"If, after installing an MSD Ignition Control, your ta*chometer, fuel pump relay or electronic fuel injection (in foreign vehicles) doesn’t operate correctly, your ap*plication may require a Tach Adapter. This is due to the trigger signal not being strong enough to trigger both the MSD and the factory’s components."
I don't know MSD said neither works for our cars so I don't know if it doesn't work on the Tib Ill just put it on one of my DSMs
Old Nov 13, 2015 | 05:56 AM
JonGTR's Avatar
Yes, you can run the DIS4. I did for several years and the standalone had nothing to do with it. I had it on the car before the standalone. The DIS is only an ignition amplifier. Doesn't do anything else but that and retard timing.
If the bypass plug works and you're sure all the dipswitches are set correctly, then you've got a bad DIS4. Tell us all your dipswitch settings.
I don't like buying anything electronic used for this reason.
Old Nov 13, 2015 | 06:16 AM
JonGTR's Avatar
Yellow is a trigger signal and Brown/Yellow is to the coil for that trigger. Violet is ground. Brown/Violet is NOT used.
Read the instructions and try again. Read page 11 only. Wire it EXACTLY as the picture diagram shows. Don't look at the "wire color code" chart to the right as it swaps #2 and #3 triggers and can confuse you.
Do not hook up Brown/Green and Green wires as they are for the 3rd channel which we don't have.
http://www.msdperformance.com/WorkAr...id=15032386155
Old Nov 13, 2015 | 12:08 PM
patuner11's Avatar
the yellow is 4th channel and violet 3rd channel get ground what msd says to do with those tigger for 4cyl. white I have as channel one green I have going to channel two. channel going to coil channel brown white for one brown green for channel 2.
