dreams of 1.8L in 2.0L block shattered.
Old Apr 6, 2003 | 04:01 AM
  #21
Russ's Avatar
Chris, would it be possible for you to make us boys (Random and me at least) who want to destroke our 2.0 liters some custom forged rods???
Old Apr 6, 2003 | 05:07 AM
  #22
CNK Performance's Avatar
Random,
The blocks outside is identical to the 1.8 and 2.0 - even the crank angle sensor is in the precisely identicalposition. I will measure the material thickness between the cylinders on each block and let you have this tomorrow some time.
Russ -- I don't see why not ---- I am busy with the Billet rods as we speak for the 2.0 and 1.8 engines, but if you need any other size,let me know and I will make them up.
Also hang in there for a while till I can completely make up the first set of rods and then test their weight, tensle strength, tonage, and COST....
Once this is all done and I am happy with it -- we can talk.
Old Apr 6, 2003 | 02:28 PM
  #23
BTW. The pistons and rods are not the same between 1.8L and 2.0L.
The 1.8L uses 2mm domes on the pistion
the 2.0L uses a .5mm dome on the pistion
The Rods between the 1.8L and 2.0L look identical, and measured out identical, but have different casting marks on them. I'm waiting for my set of Micrometers to be retuned to me for me to do a full check down to the .0001 of a inch.
Photos to follow.
Old Apr 7, 2003 | 08:30 AM
  #24
KillerShark68's Avatar
Vehicle: 2007 Tiburon
As promised here are the pictures of the 1.8 crank in a 2.0 block. Now I want everyone to know I just took pix for visual purposes only, and for a quick ref on measurement I used a ruler to measure the gap from piston to TDC.
Random will get a more accurate reading soon. But for quick referencing it was 7mm from the side of the piston and from the center of the piston it was 6mm.
Picture 1
Picture 2
Picture 3
Edited by Red: Just wanted to squeeze the pics down so the screen wouldn't scroll half a mile over wink
[ April 10, 2003, 09:32 AM: Message edited by: Red ]
Old Apr 7, 2003 | 03:14 PM
  #25
XtremePc's Avatar
from what i remember this is actutaly a good thing performance wise as longer rods have a
slower Piston Velocity and less crank angle
wich is better on turbo engines as it allow's slightly more compression to be used before detonation is a problem
Old Apr 8, 2003 | 11:29 AM
  #26
RANDOM? Hows it coming along with your 1.8 in 2.0 block measurements? Got any pix or anything yet?
Old Apr 8, 2003 | 12:39 PM
  #27
2 UNIQ's Avatar
Lets wait and see what Chris says about the Pistons between the 2.0L and 1.8L and see if they are different OR the same smile.gif
Old Apr 9, 2003 | 11:48 PM
  #28
BUMP...Random anything yet poke
Old Apr 10, 2003 | 01:14 AM
  #29
preliminary measurements.
Pistions are different, rods are different.
1.8L pistions have 2mm dome
2.0L pistions have .5mm dome
2.0L rods are about 5mm longer than the 1.8L rods.
Old Apr 10, 2003 | 01:41 AM
  #30
Red's Avatar
Red
Wow, considerably different than we were expecting. I need to call you again tonight smile.gif You tried the 2.0L rods, 1.8L crank and 1.8L pistons in the 2.0L block?
