Clicking noise after hard driving (Solo driving)
Old Sep 27, 2003 | 04:19 AM
alz99's Avatar
Vehicle: FX Coupe
what if you up'd the oil pressure?
I get this prob sometimes, mainly if the car is at idle.
Old Sep 28, 2003 | 05:47 PM
You could probably up the pressure.. have the bypass changed to do so.. But I would be weary of blowing seals.. If anything, the best results would come from taking the head off of the engine and opening up the oil passages to the Lifters... and making sure there are plenty or returns to the pan!
Old Sep 29, 2003 | 05:01 AM
Mitch's Avatar
I like your Idea Mad-Machine, I'm just not the machanic type of guy so I would have to get it done by someone.
But I have found a way to stop it yesterday. We had a solo event yesterday and after my first run I was getting the clicking noise so I hold the rpm at 2000rpm for about 1 minute and it stoped! I guess that was enough to get the oil going around again.
Old Sep 29, 2003 | 06:10 AM
Another thing you could try... I forget what company makes them.. but you could run a bottle that holds oil under pressure.. when the pressure drops (where it is connected to the engine, usually at the filter or oilpressure sender) it will send up to two quarts of already pressurised oil into the engine..
Old Sep 29, 2003 | 06:33 PM
Default I think it's rev A
Here you go... the Accusump
http://www.accusump.com/
Old Sep 29, 2003 | 10:08 PM
Hey Mad, watch the double posts mang. Just hit edit in the last post to add your new info duder.
Old Sep 30, 2003 | 01:18 PM
Sorry, just wanted to get the info out there. They also make a version for prelubing your engine before start up... considering how much wear and tear takes place on start up.. not a bad thing at all.
