Check Engine Light Won't Go Away.. .. ..help!
The only auto place we have around here is Advanced Auto, & they don't do it anymore. Auto Zone is about 1 hour away. I found a scanner to use though (my family has everything.. .. ..lol), and the codes are P0121 (Throttle/Pedal Position Sensoor/Switch A Circuit Range/Performance Problem), and P0122 (Throttle/Pedal Position Sensoor/Switch A Circuit Low Input). I live right outside Hughesville, PA. The only thing we didn't do is check the wiring to the ECU. What he told me is the TPS is getting little to no voltage. I can check the wiring to the ECU tomorrow, it's too dark out now, & I'll get back to you on that.
How did you "Check the ecu"?
Also, have you looked on webtech to see what the trouble shooting procedures are?
