Check Engine Light!?!? WHAT?!
Old Mar 2, 2004 | 08:39 PM
  #21
KayDM's Avatar
but who wants to pay for a bad 02 sensor?...not me.
Old Mar 2, 2004 | 09:13 PM
  #22
o2 sensors are cheap.
Old Mar 2, 2004 | 09:27 PM
  #23
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...item=2462861150
i would wait until it ends though, then ask him how much he wants for it.
Old Mar 3, 2004 | 05:45 AM
  #24
Mitch's Avatar
Default Things you found out
Mine comes one every few months and to make sure it's not serious I reset the computer and make sure it doesn't come on again. The last time it came on this summer it was a code for my Batery being overcharged. I had everything shut off in the car during solo racing and my batery overcharged!
Old Mar 3, 2004 | 07:55 AM
  #25
javageek's Avatar
My O2 sensor trips the CEL whenever it rains. I think I have a bare wire or something. When I install my headers I will have to investigate.
Old Mar 5, 2004 | 04:59 PM
  #26
not2happy's Avatar
Water might be getting into your connector too. You might want to cover them with some high temp RTV.
Old Apr 27, 2004 | 04:04 PM
  #27
cjme2002's Avatar
okay, i figured i'd post my happy little CEL problem here so i didn't start another thread about the same thing...
i went to gatlinburg this weekend and about 3/4 of the way there, the CEL comes on. i thought maybe it was because my boyfriend filled up my tank and didn't click 3 times. next time we filled up, i made sure to do it RIGHT and eventually, it went off. two days later, it comes on again. we hadn't filled up since the last time. it's been 2 days since then and it's still on. i can't get it to go off. a couple weeks ago, i threw a CEL, adjusted the gas cap, and it went off eventually. the car runs fine and nothing is out of the ordinary. I don't think it coming on 3 times in a month could all be from the gas cap (cause i'm really careful about it).
the only thing i can figure is it might be the o2 sensor. i got the ssa header and installed it. it made my exhaust rattle, so my dad fixed it. i wonder if maybe it's knocking the o2 sensor out of wack or something. I DON'T REALLY KNOW!
basically, i'm asking this: should i just suck it up and take it in? it's buggin the crap out of me.
Old Apr 27, 2004 | 04:15 PM
  #28
Default Ouch! (Dragbike)
get a mechanic to scan it with a obd2 scan tool. post the codes it shows up here, and with webtech i can show you exactly what the problem is.
Old Apr 27, 2004 | 05:00 PM
  #29
morningla's Avatar
Vehicle: na
I just ignored the light, mine was on for 2/3 weeks before it went away. I absolutely did nothing to it at from the time it went on to the time it went off. I am thinking now it might be the cold weather/water/moisture on sensor/gas cap lose... or all of the above.
Old Apr 27, 2004 | 06:34 PM
  #30
Get it scanned, you may have a bad Gas Cap or gasket for it. If you change altitude too much and the air in the tank expands, you can get a leak that'll pop the same CEL.
If it keeps coming and going though, I'd have to think it's a wiring issue somewhere.
