Bought Another Mod Just Now.
neat part,
but i would comfirm one thing just to be 100% sure...
check the oil pump and filter circuits to be sure you're sending filtered oil to your turbo
dirty oil and turbo usually don't give good results
I got it yesterday. Damn great service from PTuning.com Remember, they're a Tib supporter and give 5% off your order. fing02.gif
Here are some pics. I already installed it and it went on perfect. It comes with two types of adapters and you need to use the longer one. I also tapped the side port for the oil feed to my turbo. It happens to be right under the turbo, so even that worked out perfect!!!
I really suggest you guy get one if you are wanting to tap for a turbo.
http://img.photobucket.com/albums/v214/Sha...OilAdapter1.jpg
http://img.photobucket.com/albums/v214/Sha...OilAdapter2.jpg
http://img.photobucket.com/albums/v214/Sha...OilAdapter3.jpg
Awesome, can you do me a favor and post up clickable thumbnails bro? The big pics are great, but too big for random surfers.
Just check the box for the pics you want, go down to the drop down box and have it Generate IMG Tags. On the page that comes up, select the "Clickable Thumbnails for Message Boards 'Recommended'" box, highlight, cut and paste.
Try it out.
Awesome though.
About the discount, is that on anything through them for the site? If so, post it in the discount section, or PM me about the info that is needed to get the discount and I'll add it to there.
Try it out.
Awesome though.
Just go to NewTiburon and click on the banner at the top. It automatically throws the discount in your order.
I tried the thumbnail, but I'm not sure how to use the code. I'll just leave it clickable.
Thumbnail is easy man. You check the box for all the pics you want.
Go to the bottom of the screen to where it says "Please Select Action".
Hit it and go to Generate HTML & IMG Code.
Hit Go.
The page that comes up, go to the THIRD box down that says "IMG clickable thumbnails for message boards - recommended"
Click in that box, it will highlight the entire box. Hit Control and X to cut it and then Control and V to paste it into your post here.
That's it.
Hit Go.
That's it.
